Question about Garden
Rototiller belt configuration
I have an older 18'' rear-tine rototiller Make S?????? Model 60 4034 1 with 5hp B&S engine, and I can not figure out how the belts should be routed through the pulleys and idlers. I can not identify the Make and therefore can not get a schematic or diagram showing the correct belt layout.
There are 2 belts, 1 which drives forward and reverse and the 2nd engages the tines. The rototiller did not work when I bought it. I have crossed the old belts to new but they do not work or were wrong or on incorrectly, etc. How do I find out the right belts to use and how to put them on?
Can anyone advise the MAKE from the Model number so I can track down a diagram or get the correct parts, or suggest how best to route the belts, measure the belts, etc?
Thanks
#1 Taper
  • 1041 Answers
SOURCE: rototiller won't start
There are a number of thing that it could be, so lets start from the beginning. Check these off the list as we go:
1. Does it have fresh gas?
2. Check to see if the fuel line(s) are in good condition; (no cracks/breaks).
3. Make sure the fuel filter is not clogged.
4. Do you still have the original carburetor guts in it?
5. Make sure that the carb. is good and clean. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean all the small portals/jet. (Use carb. cleaner)
If you have any other questions, just let me know.
Jim
Posted on Jun 10, 2009
  • 115 Answers
SOURCE: broken rototiller
take the gear box is not in a bind.
Posted on Jul 04, 2009
pippall
  • 1486 Answers
SOURCE: roper rally rototiller wont till
Check belts
Posted on Jul 06, 2009
  • 203 Answers
SOURCE: Replace belts on Montgomery Ward rear tine
Go here and you can download a free manual for your machine.
http://lawnandgarden.manualsonline.com/manuals/mfg/montgomery_ward/tmo39083a.html
Posted on Oct 25, 2009
  • 221 Answers
SOURCE: have a rototiller it moves ok but the tines do not
Seems to be a fairly common problem with these units. If the big pulley is turning which I assume it is as the drive wheels work, it is most likely a problem in the gear box. The shift mechanism in these units leave a lot to be desired. You can try to repair it your self or take it to a service center. Labor will be high due to the amount of time required to separate the engine and transmission.
Posted on May 06, 2010
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
Need belt diagram wizard rototiller rear tine
-It's sample. just open the cover than you'll figure out.
-Or what brand and model...?
Good luck
Mai
Sep 02, 2014 | Garden
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
Replace belts on Montgomery Ward rear tine rototiller Model number GIL39012B need diagram
Oct 24, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
Garden Logo
230 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
