Question about Samsung DLP HL-P5663W 56" TV
Same dark bar
I have the same problem on my Samsung. It just started. Anyone found a solution?
I just purchased a new hisense 40 inch smart led television but I seem to have misplaced (thrown away) the manual. I am wanting to add a sound bar but I am unsure of what type to buy because I am unsure of...
its a smart tv it will have an optical plug in. I have a samsung sound bar and a 50" LG the samsung has a optical input on it. look on the back of the sound bar you will see two spots that have a rubber flap on it and say optical on it
Feb 26, 2013 | Televison & Video
Samsung tv model UN40C5000 has a dark spot in the top center of screen. Can anyone tell me how to repair problem .
Dark spots might be due to energy recovery circuit board's fault. If you wish to get more details about these type of faults to Samsung TVs, check this link.
Feb 05, 2013 | Samsung UN40C5000 TV
My Printer Prints Out Too Dark
go into printer properties and change the setting....you probably are using an after-market cartridge...they are notorious for being too dark....even if that is not the case, go to printer properties and change the setting....if there is no slide bar for heavy to light, then clik on toner saver, it should print lighter than it does now
Apr 27, 2012 | Samsung SCX 4600 multifunction Laser...
I have a Samsung 61' but for some reason the view
it depends on what model number is---some of the older sets have lens that require cleaning(pretty easy) and to help I need to know the model number.
Mar 19, 2012 | Samsung Televison & Video
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Acer aspire 5520 start up screen
can you go to bios? load default setings in bios, or optimized settings, then try... when something like that happens i usully pull out batery on mother board, than wait about few seconds and pul it back in... bu that is to much work. try above,, and let me know
Feb 15, 2009 | Acer Aspire 5520-5908 Notebook
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung DLP HL-P5663W 56" TV Logo
95 people viewed this question
Jerry Greenberg
Jerry Greenberg
