Question about Coleman Mach III Air Conditioner
My compressor on my coleman tsr will not kick on I can turn the thermostat all the way down and then ease it up the compressor never will come on it worked fine the day before
    Novelist:
  • 127 Answers
Check that the thermostat is OK. You can do this with an Ohmmeter or a Volt Meter. If it is cool only, there are two terminals on the rear. Cut power to the AC and remove these wires and with an ohmmeter, check the two terminals for continuity. If there is none, then turn the dial all the way to the coldest setting and see if it changes. If not, you have a bad thermostat. If you have continuity and the compressor still does not come on, check the Start Capacitor in the upstairs unit.
Posted on Jun 30, 2009
  • 508 Answers
Make sure thermostat switch is turning properly,maybe stripped? Good luck!!!
Posted on Jun 21, 2009
Compressor won't kick on
You should be able to hear the compressor kick in. If you don't the most likely culprit is the capacitors. I generally keep spare capacitors on hand at all times, because they are mostly likely to fail on a holiday or a weekend when it is 102 in the shade. If replacing the capacitors doesn't work, you want to look at the thermostat. You will have to look up manuals and testing for your thermostat. And if those things doen't solve your problem, sadly and lastly, you will want to do troubleshooting on the control module in the ceiling. The control module generally resides in the ceiling and you access it through the vent in the ceiling.
Here is where you can find manuals for your a/c unit. Click on the links under the tab for technical information. Airxcel RV Products Good luck!
Apr 07, 2014 | Coleman Mach III Air Conditioner
COLEMAN TSR FULL LOAD AMPS
Go to airxcel.com, you should get some options, to get either their literature or tech support and they should be able to help you.
Aug 07, 2012 | Coleman Mach 15 Air Conditioner
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor...
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Sep 14, 2009 | Coleman Mach III Air Conditioner
COLEMAN TSR MACH 3 COMPRESSOR
I would check the thermostat based on what you said it could be out of calibration
Jun 11, 2008 | Coleman Mach 15 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach III Air Conditioner Logo
697 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
