Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
Rca universal remote control code list - RCA 3-Device Universal Remote with Dedicated DVD Menu Key
SOURCE:
Gigatech
  • 259 Answers
SOURCE: RCA Universal Remote Control Code
sony code is 002
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Posted on Dec 16, 2007
SOURCE: RCA XL100 Remote Code?
I found a remote on the web for that model and purchased it.
Posted on Apr 11, 2008
TVtechmaniac
  • 140 Answers
SOURCE: "Code List" for RCR311B
http://remotefinder.rca.com/default.aspx?site=rca
Select your remote model RCR311B from the pull-down list, then select the device your want to program, then select the brand and it will give you the codes....
Posted on Jul 22, 2008
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
Posted on Oct 08, 2008
  • 17 Answers
SOURCE: lost program guide for rcr3273 rca universal remote need codestoo
Go to thompsontv.com/carc.html
Posted on Oct 30, 2008
Need code for RCA Universal remote RCR314WR To set up RCA TV detg188r
Here's a link to the RCA RCR314WR remote control user manual and code list:
Information Owner Manual Remote Code List and Support for the RCA RCR314WR...
Click on the link for the codes to find the code you need for your RCA TV
Apr 10, 2016 | RCA Universal Remote Control
Tip
RCA Universal Remote Code List Models RCR312W - RCR311BN - RCR311BIN RCR311SN -...
RCR311SN - RCR311STN
Would like to program your RCA Universal Remote, but have lost your code list?
The RCA Universal Remote code list can be downloaded here.
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
Tip
The RCA RCR311S code list can be downloaded here.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
What is universal remote code for bd-2000 on rcrno4gr remote
Remote code for HP BD-2000 Blu-ray player - AT&T Community
https://forums.att.com/.../Remote.../Remote-code...BD-2000.../467...
AT&TDec 2, 2012 - I have an HP BD-2000 Blu-ray player that I recently lost the remotecontrol for. I do not see HP as a manufacturer on the DVD list when I try.
Universal Remote Control Codes List - TV SAT DVR ...
removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Nov 10, 2013 - We compiled this universal remote programming code list to make it ..... Looking for a code for a orion vcr I have a 5 digit universal remote by rca -rcrn04gr and I ... remote control code (s) for a samsung blu ray dvd player bd-fm51 /ZA ... Please, could someone to give me the code for DENON AVR-X2000.
Programming the RCA RCRN04GR Universal Remote
voxrightnow.custhelp.com/.../programming-the-rca-rcrn04gr-universal-r...
Jul 28, 2010 - Program your Remote. To use this universal remote with your home entertainment system, first you need to program it to control your devices.
[PDF]Rcrn04gr - Universal Remote Control Codes
Jan 19, 2016 | HP bd-2000 blu-ray player with 1080p...
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
Tip
The RCA RCR311B code list can be downloaded here.
I hope that helps.
on Apr 07, 2010 | RCA RCR311B Remote Control
WHATS THE CODE FOR RCA TV ..I HAVE A ONE FOR ALL UNIVERSAL REMOTE NEED THE CODES TO PROGRAM MY RCA TV
You received a list of ALL Codes with your universal.
I got this off the internet. But I do not know what type of universal you bought. You didn't mention it.
Good Luck.
Here is the link if you need it. :0)
http://www.google.com/search?q=universal+code+for+rca+tv&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
rca
Nov 07, 2009 | Universal Remote Control P000203220-1...
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Rca remote control code list
i need the codes for a rcu404 universal remote for sony dvd player
Jan 11, 2009 | RCA RCU404 Remote Control
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
183 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
