Question about GE JE1390 Microwave Oven
I have a Emerson AR550 microwave oven & would like to know what is the correct fuse specs to buy....Also where can I get the the three (3) legged plastic device that spins the glass tray? Thx for all your input.
  • 149 Answers
Should have specs on old fuse or labeled at fuse location...look in yellow pages for appliance parts.
Posted on Jun 22, 2009
I have samsung microwave model MW830WA 120V 60HZ 800W IT IS DATED 2001. The fuse has been blown off last week. I want to know where the location of the fuse and what fuse to buy. Thank you, Phil
I know on my samsung it's right on top when you take off the outer cover. I also have an emerson and it's on the right side behind the control panel There is a white plastic cover over the fuse that just snaps apart.. I buy my fuses at radio shack. I know mine takes a 20 amp 250 volt.
Aug 12, 2010 | Samsung MW4699S Microwave Oven
Emerson mw810255 how do i check fuse? where do i
15A & 20A ceramic fuses can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Your fuse can be tested with a test light, continuity tester, multimeter, etc.
You should also check the thermal cutout / thermostat on the magnetron in your oven is truly dead.
If you need other parts, call
866-779-5835 toll free.
Nov 24, 2009 | LG LMV1650ST Microwave Oven
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave oven will not turn on. no light, no display.
First check breaker at breaker panel. Then if you remove the front vent and key pad you will find a paper with breakdown of unit. Look for fuse, check with a tester, if bad replace, if not check all cavity switches, approx 3 or 4, test these. One of these three checks should solve your problem.
Jul 03, 2009 | Emerson Fans Emerson 1052466 1000 Watts...
Need a replacement fuse for an Emerson Microwave Model MW8774
Please understand there are some liability issues that Emerson or their parts supplier have in selling you the fuse.
You should be able to find one by going online and searching with the terms you gave, using Google. I just did, and there are a number of hits to choose from.
Try Sears Parts Direct or Repair Clinic as well. You will need to enter your model number to find the parts listing.
In all likelihood, you have a failed controller board or microwave circuit (magnetron, transformer, diode, capacitor). Be prepared for additional troubleshooting.
REPLACE THE FUSE WITH AN EXACT REPLACEMENT> DO NOT REPLACE WITH A LARGER (more amps) FUSE TYPE.
Jan 16, 2009 | Emerson MW8777W Microwave Oven
Emerson mw
Call any service center that services appliances or most any electronics parts supplier. You will have to know the specs of the thermo fuse to order one.
If the thermo fuse is blown, most likely there was an overheating condition, and there is a failure somewhere. This can be a serious safety issue. When you change the fuse, it may blow again. It would be best to verify the specifications and for proper operation of the unit before using it again. A qualified service center for microwave ovens can do this for you.
Jerry G.
May 03, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Thermal fuse MW8102SS Emerson microwave
normally the THERMAL FUSE is located in series with the 20 AMP power line fuse ,in most cases. hope this helps
Apr 07, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave won't work...Emerson MW8102SS
the THERMAL FUSE is located in series with the 20 amp power line fuse , in most cases. hope this helpful
Emerson Mwg9111sl microwave blows 20 amp internal fuse instantly everytime.
check your thermal fuse its about 2 inches long white on the outside black on the inside it has 2 wires going to it check for
cotinuity becareful of the capacitor you need to disapate that first by touching the two teminals together with a screw driver
Apr 01, 2008 | LG LTM9000 Microwave Oven
Broken turntable support
Microwave-safe epoxy would be better than super glue, which will will emit fumes.
You would be better off getting a new one if it's truly available.
Tritronics (http://www.wehaveparts.com) shows it as part # M0R0282 (no rollers included) and the rollers are part #
M0R0272. You rrollers may work if they're okay.
Oct 13, 2007 | Microwave Ovens
GE JE1390 Microwave Oven Logo
202 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
