Question about Sharp DM 2010 Laser Printer
Sharp dm 2010 Unable to connect printer function.
Hooked up and works for fax and copier. unable to communicate with computer for printing. Have both xp and vista. uses serial port on printer which does not have usb. Does the printer need some directions in a setup? thank you
    Brigadier General:
  • 4,090 Answers
You may need to tell the installation program that you are connecting via serial port. Com 1 usually.
Posted on Jun 21, 2009
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Unable to do fax can print but unable fax
Canon PIXMA MP250 series serves with PRINT + SCAN + COPY function. No FAX function
Jun 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Faxing Hp Photosmart C8160 Solution Center Doesn't Work
This might be one of the communication error issues,
if your printer is connectd to your computer tower using the USB cable make sure that the cable is not too long and also it would be better if you are using the cable that came with the printer
also check if the printer is not connected to a surge protector,it should be onnected directly to a direct power outlet.
check if you do not have multiple icons of the printer in the control panel under printer nad faxes
check if you have the right tab chosen for the printer in the solution center.
try a semi full reset which is # and 3
AS you said that a paid hp support couldn't resolve it
i offer you a free technical support.
i have troubleshot HP all in Ones for 2 years and would like to help you with this...
Jun 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Sharp MX-M350N Error CE-03--We changed ISP providers and can't get Inbound routing to an email working again. I changed smtp server in "Network Setup". The "Connection Test" passes for SMTP. We can email...
CE-03 is a communication error, obviously. Your print card and your new SMTP are not talking together. Your system is probably OK at this point, but is unable to communicate well with the new network system. Work with an IT department to resolve this.
Jun 02, 2009 | Sharp AR-M450N Copier
Unable to print pictures from my coolpix camera
Do you have your camera software installed on your computer?
You need the drivers for your camera.
Drivers are small pieces of software that allow the device, (In this case your camera) to 'communicate' with the Operating System.
(MAC OS X 10.5.5 {Leopard} is an example of an Operating System)
Plug your camera into your computer. Print from your computer.
Apr 24, 2009 | Apple ~:~ BROTHER INTERNATIONAL CORP ~:~...
Receiving Fax
- If the Printer is connected to a router, you have to configure your router to allow the communication on it.
Mar 11, 2009 | Brother MFC 490cw Color Inkjet...
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc-215c unable to clean?
@artkoy:
There is no Error 10 within the maintenance of the printer!
An error starting with 10 (and two more digits) belongs to the communication device (fax).
Plz check again what two digit error you have and post again.
@peter:
you need a new waist ink absorber. plz check the forum for unable to clean or error 46. Its explained many times.
Mar 27, 2008 | Brother Multi-Function Center® MFC-215C...
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Sep 13, 2007 | Sharp AL-1661CS All-In-One Laser Printer
Sharp DM 2010 Laser Printer Logo
113 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
