Question about LG WM2233H Front Load Stacked Washer / Dryer
Machine is solid and level. going into spin w/clothes it starts to vibrate and shake. How do i stop it?
    Sergeant:
    Champion:
  • 208 Answers
Make sure the load is evenly distributed in the machine
Posted on Jun 21, 2009
Washer will not stop shaking during spin cycles, we have removed akll shipping bolts
Place a load in the machine use a good level to get machine perfectly level. Now put machine on spin and check the feet. Find the one that is not solid and slowly adjust it until it stops shaking. PS place level on flat top surface and level side to side and front to back.
Jan 26, 2010 | LG Washing Machines
Washer shakes terribly in spin cycle
Does the floor or the walls shake? If they do you have to beef up the flooring under your washer, with blocks between the floor joists, piers, or sistering of the joists. If there is no shaking of the floor or walls, and your washer is solid on the ground, leveled and not rocking, then it is your washer. Lg has problems with too much vibration in their washers. Check to make sure that your lint filter/coin catcher is clean. Open the door in the bottom front, put a towel down to catch the water, Unplug the washer, and unscrew the large plastic screw that is the filter for your washer. If this has debris in it clean it out completely. Look in the hoses also, if your water drain is restricted by lint or coins or other debris, the washer has clothes in it that are wetter and heavier than they should be, and this will cause sever vibration. Good Luck, Appliance Specialists
Jan 26, 2010 | LG WM-2277HW Front Load Washer
I have a LG WM2032HW Front Load washer that shakes like crazy! It is level, shipping bolts are removed and it does not matter if the washer is empty, just a small amount of clothes or full!
your problem may be in the shocks or because this machine is very powerfull and spins very fast that the floor is giving (has play) and needs to be supported up from underneath it if u put the machine on a cement floor lock the legs securly to the machine if it spins fine then your floor is the problem
if it still shakes then i would replace the shocks
(sol v ya prob)
Oct 17, 2009 | LG WD-1280FHD Front Load Washer
HAVE A LG TROMM FRONT LOADING WASHING MACHINE THAT SHAKES WHEN SI
has one of the shocks come loose or broken. Open the back of the machine (power-off of course) and on either side of the drum there is a shock absorber. A visual check should tell you if there is a problem.
Apr 15, 2009 | LG WM-2277HW Front Load Washer
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
LG Tromm
Place a good level on the top of the machine where it is flat. Check front to back and side to side. Level machine exactly. Now put a load in and when it spins feel the feet for any that are not solid on the floor. Adjust the foot down until the machine stops shaking.
Apr 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool duet sport..vibrates during spin and "walks"..on pedistal.sitting on tile
I just bought this washer and had two problems with it. 1 the vibration at medium spins and 2. a squeeking spring (every time the drum rotates a little squeek, but when spinning the squeek sounds constant.
What I discover in solving both my problems with the same solution. I had to ensure all 4 feet well on the ground and that the top of the washer was perfectly level. At one time I was out only about 2 mm on one side, but the bubble was slightly to one side on the level but still in between the level's markers. I tested with a load, and both problems were still there. Turn feet 1/2 turn on the side needing adjusting. Ran another load and you guessed it, no squeak, no vibration, spinning was quiet, I had to go over to check to see if the machine was going through the cycles. I couldn't believe that a few millimeters could make such a difference.
Now I am pleased with the performance, not to mention how clean the clothes are and the savings on water and drying.
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Noisy spin cycle on washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 11, 2007 | Zanussi FLE1416W Front Load Washer
LG WM2233H Front Load Stacked Washer / Dryer Logo
159 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
