2007 Lincoln Navigator Ultimate 4x4 Logo
c
crystal husk Posted on May 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What could cause a loud metal scraping noise in the back of lincoln navigaitor while backing up?
michel villeneuve
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 159 Answers
  • Posted on May 03, 2014
 michel villeneuve
Expert
Level 2:
Cheetah:
Night Owl:
Answers
159
Questions
0
Helped
28184
Points
288
Need more info could be a bicycle or just brakes squelling
steve
Level 3:
  • Lincoln Master 3,718 Answers
 steve
Lincoln Master
Level 3:
Answers
3718
Questions
Helped
964386
Points
12533
Loose exhaust part or something to do with the running gear is the best you want to find other wise could be a tranny problem ,so start with checking the oil/fluid level and take it from there
1helpful
Hi my engine make noise when i accelerate and stop when hidling its fordbantam 1.3 2007 rocam
It’s difficult to say because engines make a wide variety of noises.
Rattling, possibly a worn timing chain.
Misfiring, possibly incorrect valve timing or damaged head gasket.
Metallic scraping, possibly a lack of oil pressure causing bearing to run dry.
Knocking, possibly worn mains or big end bearings.
Loud exhaust noise, possibly a blown exhaust manifold gasket.
There are a wide variety of possible noises and therefore a wide variety of possible causes
Loud metal noise from right rear wheel Volvo v70
If they're drums could be rust on the drum rubbing on the backing plate, or a loose brake component rubbing inside the drum.
2008 malibu noise when turning steering wheel
Make sure its attached tight, take it to a local repair shop if that does not help.
2007 Cadillac escalade makes loud noise when starting the car. Sounds like the air suspension on a navigator when it adjusts, but louder. Lasts maybe 20 seconds. Happened 3-4 times within the year. Any...
Try to better describe the noise.
Is it a
scraping of metal
grinding / rubbing
high pitched shriek like a drive belt slipping
Is it
underneath the body
under the hood
in the aircon
when you pull into gear
when you pull away
etc
Do a bit of detective work and come back.
Discovery 3 handbrake noise problem
what type of noise is it a scraping noise if so need new shoes on breakes asap befor down to metal causing damage to drums or try scraping a big screwdriver around edge as a build up of rust around edge can also cause noises
What is this horrible scraping sound?
have the breaks checked....make sure the lugs are all present and do not appear loose....see if the brake fluid is low too...if that is what's leaking....
Loud scraping noise when turning corner or backing up
The scraping noise may be a "tire rub," where one or both front tires are rubbing the wheel
wells during a turn (going forward or backing up).
Cause: possible ties size may be a little larger than the tires specified by Dodge for the vehicle.
Check: the driver's door panel, which will show manufacturer-recommended tire sizes and inflation pressures.
2answers
When i hit the brakes i hear a lot of noise and the passenger side rear wheel moves
YOU BETTER GET TO A BRAKE SHOP AND FAST, SOUNDS LIKE YOUR REAR BEARINGS OR TIE RODS ARE GONE AND YOUR PADS ARE WORN DONE SO BADLY THERE IS METAL TO METAL CONTACT. YOU BACK WHEEL COULD FALL OFF. VERY, VERY DANGEROUS.
OCCASIONAL Metallic scraping noise - New ceramic brake pads.
You could be right with the wheel bearings. But first take the wheel off and check that nothing is scraping the rotor. Look all the way around the rotor. A suggestion will be that the brake pads have worn enough that the brake pad wear indicator is starting to scrape. Pry them back a little.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
