Question about LG 22" FLATRON LCD Monitor
My monitor just shuts off and can,t turn it on
  • 721 Answers
Check the video card by using another monitor. If ok,replace the monitor.
Posted on Jun 21, 2009
1707fpt dell flashes video and green power light
i will give you some tips
1- If the power light goes from green to orange) this is almost always an issue with the computer and not the monitor
2- If the monitor power light turns off, then it is almost definitely a problem with the monitor.
there are some reasons your monitor turning on and off
01-One reason the monitor could shut off is because it is overheating.
02-If the power cord is loose and is not securely connected to the back of the monitor it will cause the monitor to turn off.
03-If the monitor is staying on, but you loose the video signal, it's very likely an issue with the video card or motherboard in the computer. This could also be an issue with the computer or video card overheating or a defect with the video card.
04-Another reason the monitor could shut off is because of a malfunction in the circuitry. There could be a short in the wiring or some other failure in the circuitry, causing the picture to go black or causing the monitor to shut off completely
05 another reason the monitor on and off is because your monitor power supply chipset is damage
hope that it will help you
Feb 15, 2014 | Dell Computers & Internet
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor turns on and then shuts off
HAVE YOU CHECKED THE BATTERIES ,,MOST OF THEM DO,,MOSTLY 2 AAA BATTERIES
Sep 28, 2008 | American Diagnostic Corporation Advantage...
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
LG 22" FLATRON LCD Monitor Logo
261 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
