Question about Nokia 6300 Cellular Phone
Voice message icon keep appearing
I can't seem to remove the voice message icon. It's on the top right hand corner where the battery signal is.
I called the voicemail but no new messages and yet the icon does not disappear.
Anyone has any idea?
  • 45 Answers
Re: Voice message icon keep appearing
Dear reset the phone
switch on the phone and type *#7370#
set will ask the security code (12345 is default)
type it that will reset.
Posted on Nov 07, 2007
0 characters
3 Points
How do I turn the voice mail alert icon on to appear on the screen?
with all the new updates it doesn't appear at the top of the screen now as an independent icon, it shows as a missed call & a voice mail in notifications, you can acces it direct from there or when u go into the phone section if you flick left to right past speed dial there is a devoted section for voice mails, that shows each 1 individually & who left it, just click on the 1 you want to play, listen & delete or keep, you no longer have to dial the voice mail.
Apr 04, 2015 | Nokia Lumia 520 Windows Phone Black
How do you know if you have a voice mail message
Yes, the was bothering me for some time. I think the indicator is a little green light that blinks in the extreme upper left hand portion of the phone...not on screen, above it....but the blinking light may indicate a missed call or a voice mail is present.
Try this. Go into your phone icon, press and hold '1' and listen to any open messages. Delete each. Next go into your Call Log and delete all call history. Now exit.There should be no green light flashing in the upper left hand corner of phone. You have just cleared everything.
Next call your phone but hang up before leaving a message. Note the blinking green light in the upper left hand corner apparently indicating you missed a call. Go into your Call Log. It will say one missed call. Exit the call log and note that the blinking light is now off. You have acknowleged the call in the call log so the light goes off when you exit.
Call the phone again. This time leave a message. Note the blinking light again. Go into your call log again. Note the missed call. It would be nice if there was an icon or something HERE that indicates if this call left a voice message....but there does not appear to be. Exit again. This time note that the light continues to blink even though you entered the call log and acknowleged the call. I believe it continues to blink because you have a voice message. Exit.
Go into the call log again. Delete the missed call from the call hsitory. Exit. The light still blinks, I believe still indicating a voice message.
Go to your phone icone. Press '1' to check messages, delete the message and exit. The blinking is now gone.
So it appears a blinking green light indicates a missed call. If it still blinks after exiting the call log, you have a voice message.
If someone figures something else out let me know because this stinks!
May 28, 2014 | AT&T GoPhone Radiant
Deleted voice mail in error, is there anyway to retrieve?
  • Start by tapping the "Phone" icon on your iPhone.
  • 2 Next, access your voice mail messages by tapping the "Voicemail" icon.
  • 3 Look at your list of current voice messages. If you have any messages that are eligible for recovery, you'll see an item at the very bottom called "Deleted Messages". Tap on this to access a list of your deleted messages.
  • 4 You should now see a list of deleted voice messages. If you see the message that you want to recover, tap on it and choose "Undelete".
  • 5 Your voice message will now be sent back to the main list of current voice mail messages.
  • 6 Repeat steps 1-5 for "each" message you wish to recover. This may take time!
  • Read more: How to easily recover accidentally deleted iPhone voice messages '
    Dec 05, 2010 | Apple iPhone 3G
    The voice mail icon won't go away, even though I
    full factory using jaf or ufs gadget will solved your problem.go to the nearest cellshop sir.
    Jun 16, 2010 | Nokia 6101 Cellular Phone
    Voice mail message icon won't go away
    first inactive ur voice mail service. then check outbox if any outgoing sms or voice mail r there then delete it.
    Jul 30, 2009 | Nokia 6085 Cellular Phone
    Voice Message Icon always displaying
    The voice mail symbol is sent to your handset by the network when you get a voicemail, they then send the handset another message to remove the icon once you have listened to the voicemail... Sometimes an error occurs and the phone doesnt receive the removal message...
    Try getting a friend or using another phone send yourself a voicemail, then using your phone, check your voicemails, listen to the one you have and delete it... The icon should go... However if its a hardware fault with the handset display then this will not fix it...
    May 07, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
    Unknown icon
    I had the same problem for awhile too.
    The box is your call equalizer settings.  The descending line indicates "boost bass" and the ascending line indicates "boost treble"
    This usually only shows when you have your BB headset connected, to change the settings:
    -plug in your headset -make a call, (voice mail works good for this) -press your menu button -select "Enhance Call Audio"
    -make your selection
    You'll see your choice on the screen
    Let me know if this helps 208E019D
    Apr 16, 2009 | RIM BlackBerry Bold 9000 Smartphone
    E-mail indicator shows a message (but I do not)
    I had a same problem when draft messages or other messages being saved without my knowledge.
    I have the Pearl and here's how you can check the folder.
    1. Click the message icon
    2. Press menu button
    3. Select "View Saved Messages"
    If you see any un-opened message or draft messages that you won't need, delete them.
    Mail indicator will disappear immediately.
    Hope it helps!!
    Mar 26, 2009 | RIM BlackBerry Bold 9000 Smartphone
    Removing/clearing message icon on my rumor!
    In "Messaging" go into Voice Mail (number 1) and select Clear Icon (Number 3).
    Go into Settings/Tools- Settings (#1)- Messaging (#5)-Notification (#1)- Change this To Icon only.
    Still in Messaging, select Message Reminder (#5) and change it so it doesnt keep sending reminders.
    If its telling you you have a text just go in each inbox and selcet Delete all... see if that helps.
    Feb 25, 2009 | LG RUMOR Cellular Phone
    Nokia 6300 Cellular Phone Logo
    278 people viewed this question
    Top Nokia Cell Phones Experts
    IT Solution
    IT Solution
