Washing blankets, heard a lot of banging. cycle ended up getting stuck on with 1 minute left. Managed to get door open, pulled clothes out, then ran a short cycle (drain and spin). No drum rotation, again gets stuck on zero. Display error reads ESE - diagnostic seems to be E59...next steps?
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
SOURCE: Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
SOURCE: CLOTHES ARE VERY WET AT THE END OF THE CYCLE
The pump is probably obstructed by an object. Typicial it will be a coin. You will need to gain access to the pump, which should be located on the bottom front to the machine. Remove the hoses to the pump.(Important..have a bowl or pan to catch the water that will come out of the hoses)
Turn the machine on a cycle that will turn the pump on. This will let you know if the pump is working correctly. If something is in the pump,remove the pump and remove any obstructions. Then just reverse the process to reassemble your machine. If the pump is not working thaen you will need to replace it.
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
SOURCE: Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
