Home | Canon | MX300 Office All-In-One Printer | Check ink u163 err...
Canon MX300 Office All-In-One Printer
Problem for Canon MX300 Office All-In-One Printer
Check ink u163 error message
By nirangal on Jun 21, 2009
check ink u163 error message
Best Solution
posted on Jun 21, 2009
Helpful)
nettiser
Rank: Wiz  Canon Expert
Rating: 84%, 1353 votes
Firstly I suspect you are not using genuine cartridge or you have refilled the cartridge.
To fix this you need to disable the ink checking procedure.
Do you know that low ink or ink has run out message appears once cartridge empty. If you want to use refill ink in that cartridge then you need to deactivate ink level to get your printer run as usual. Check the following tips to fix low ink error message in case of refill ink usage. Below some methods to deactivate ink level detection function for some models due to its similarity.
METHOD I:
Press RESUME/CANCEL button once
Related models:
BJC series: bjc3000,8200,etcS series: s400,600,800,6300,9000etc
i Series: i255,320,350,355,450,470d,550,560,850,950,6100,6500,9100,etc
Pixma series: ip1000,1200,1300,1500,1600,1700,2000,2200,3000,4000,etc
METHOD II:
Hold down RESUME/CANCEL button for 5 seconds or more
Related models:
Latest models of Pixma series: ip1880,1980,3300,3500,4200,4500,5200,6700d,pro9000,9500,ix4000,5000,etc
METHOD III:
Press START button once, select COLOR button for colour cartridge; BLACK button for black cartridge
Applicable models:
Pixma MP150,160,170,180,450,460,475,etc
METHOD IV:
Hold down STOP/RESET button for 5 seconds or more
Applicable models:
Latest models of Pixma MP/MX series: MP145,228,245,520,800,850,970,MX308,318,7600,et
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #2
posted on Aug 29, 2009
Very Helpful)
ashleyheil
Rank: Apprentice
Rating: 100%, 1 votes
Thanks, I had to hold it down until it printed off the page we wanted to test print. we refilled our cannon cartridges.
It does say our cartridges are empty, but at least its working.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 27, 2009
Not Rated)
aacktse
Rank: Apprentice
Rating: 0%, 0 votes
Another way to clear the error message:
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
On my Mx308, the printer does not print the test page and stop. I just press cancel and pull out the plug and put it back. The it works.
Was this helpful?
Yes
No
Popular Solutions for Canon MX300 Office All-In-One
Questions and Unsolved Problems for Canon MX300 Office All-In-One
Do you recommend Canon MX300 Office All-In-One Printer?
Answer
Answer
I have a paper jam error that wont go away even after i've pulled out the paper
Answer
How to reset error message 6000 for MX 308 Canon, thank you
Answer
im not sure how to set up scanning, i have the mx300 and I have a mac os ..tried to download the... (More)
Answer
I can't scan pictures. I am not sure if I setup the scanner feature when I got a new computer with... (More)
Answer
does our printer scan original positive images of photos to our computer if so what do we do??
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon MX300 Office All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 417
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
