Question about Goodman CLQ36AR49 Air Conditioner
Air Handler Blower
I have a 1000 square ft house and last year replaced the outside unit with a Rheem 3 ton. Did not replace the inside its an older Gibson.
Right now its 84 degrees in my house. It will cool at night but during the day from 3-9 its just hot. My coil apears clean I keep clean filters in it. Last week we took the blower out took it apart and cleaned it. The air is coming out cool but its it just not blowing like it should. We just took the front where the blower is off of the air handler and turned it on to see and wow what a difference in air flow but you cant run the air with that off I am sure and it be able to cool. What could be stopping the air flow? Could it be possible that the coil is clogged inside but looks very clean visualy? We looked at both sides of the coil and it looks clean.
Any suggestions would be appreciated..........
  • dtsalkire Jun 21, 2009
    We had the freon checked and it was at the right level. It is cooling just not blowing hard enough out of the vents :(
    Thank you for the suggestion I dont have a thermometer but will get one and see
  • 77 Answers
If you have a meat thermometer, place it in the vent when the air is on, it should be cooling somewhere around 15-18 degrees F lower than what actually temp is, so if its 84 degrees, your unit should blow around 67 degree air out of the vent. if it is not call a tech. your system could be under or over charged.
Posted on Jun 21, 2009
How do i trouble shoot/fix m1400 frosting pipe reezing up outside not cooling house
Get a high velocity air filter, not a pleated one. Check air into evaporator section clean and passing air well. Next, check proper operation of blower motor and wheel. Next, check for proper charge by performing a superheat and subcool calculation. You will need a repairmant to check these. Superheat and subcool will tell you if your unit is properly charged and if you metering device is working properly. A typical superheat and subcooling value is around 10 to 15 degrees.
Jun 05, 2014 | Rheem Air Handler 4 Ton With Rhplhm Series
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
I need to know the seer number for an air handler. I'd
On the air handler take the top panel off, look to the left on the inside, this will give you general information on the unit on a stampede plate. This will
give you the date of manufactuer as well.
On the outdoor unit, there is a stamped plate on the
condensing unit. Should have year of manufactuer, it
should also say how many pounds of freon should be
in it. The Model number is what you need to know
to find out how big it is.
024=24,000 BTU= 2ton unit
030=30,000 BTU=2 1/2ton
036=36,000 BTU=3ton
040=40,000BTU= 3 1/2ton
and so on.
My guess is that it is an older unit and since I have
been installling units since 1995 I have only known
any older units to be at least a 10 SEER and no more.
Feb 16, 2010 | Heating & Cooling
3 ton condensor and 2.5 air handler
I hate to use rules of thumb but 500sqft per ton depending on your windows and insulation. you are probably ok with a 2.5 ton however it will not work with a 3 ton outdoor unit as you have figured out. depending on how long that ac has been in you may want to replace it with a 2.5 ton due to the damage to the compressor valves because of the mis match. or if the indoor is newer and the original system may have been a 3 ton then i would replace the A/H. and be prepared to replace the outdoor if the valves are to far gone. If the trane is a new high effiency 2 and the goodman is just a 10 SEER you may be able to have a txv installed on the trane unit and a kickstart device outside. but only if its a high effiency but their again if the A/C fails you couldnt have a high effiency 3 ton you would have to drop down to 2.5,
Sep 22, 2009 | Heating & Cooling
I have a Ruud air-conditioner/heat pump and it blows 5 amp fuse.
It sounds like the thermostat wire going to the condenser is ground, It either got pulled loose and is touching the housing or as in most cases the wire got cut or was chewed by an animal. You need to turn electric off to both devices and physically inspect the thermostat wire going from the air handler to the outside unit, also inspect where they connect inside the unit. When you find the break, cut and strip each individual wire and securely wire nut each conducter red to red white to white and so on. There you go all fixed. That's when I give you the bill for $75...except this time you write that check to yourself. Good Luck
Jul 14, 2009 | Ruud UBHC Air Conditioner
Rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
Jan 27, 2009 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
227 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
