Question about Epson Stylus CX5400 All-In-One InkJet Printer
Not printing in color
Prints only in black, changed ink,cleanded heds several times, when ready to print shows all cart. full , does not print in color
  • 2 more comments
  • Anonymous Nov 14, 2007
    i have an epson stylus cx5400 durabrite printer/copier and i have a problem with the magenta not printing and i think that the cyan is soon going to be giving me a problem. i have already tried cleaning the heads with rubbing alcohol and then tried doing a print-out of that particular colour and it wouldn't give me the time of day. how do i go about fixing it?
  • Anonymous Dec 16, 2007
    My Cx5400 All in one ink jet printer will not print in color, Black onley.
    I have changed all of the cartridges and done all of the print head steps.
    no change. please help.
    thank you.
  • marysecd Sep 26, 2008
    Yes, I have the same problem, the magenta does not show even though the ink leveL for red indicate 100%, just put a new cartridge in...
    I have done the head cleaning and nozzle check many times, so many times that the ink levels are getting low.
    No trace of red whatsoever.
  • whisky7878 Oct 10, 2008
    black and blue print yellow and magenta don't
  • 1,447 Answers
Chances are the tubes are clog and you need to dismantle the printer to clean it, if you have tried cleaning the heads several times then nothing change. Might as well have it service or buy a new one, call epson customer service- 562 276 4382 or 1300 so that they will offer you the loyalty website and you can get a new epson printer, discounted in price.
Hope this help
Posted on Sep 22, 2008
What cause lose of new ink on aligning cartridges.
Unfortunately, the printer does not actually measure the ink in the carts, but measures how many droplets called for. The carts may actually be full, but the printer now thinks they're empty. Most likely the black ink needs to be "charged" because you've cleaned out the pipe. I don't know what to do to charge it, and you'll likely need new carts.
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
Color printing
The printhead has either become too clogged to flush out with with the internal cleaning operation (which uses a LOT of ink), OR, the nozzles are not firing. If after several cleaning operations there is still no significant improvement, you will need to replace the print head. I see this frequently with Canon and Epson, and Brother inkjet printers. Usually, it is due to leaving the printer idle for too long, or removing a cartridge and not replacing it right away. The air gets to the residual puddle of ink in the head and dries it. Also, using compatible or refilled cartridges can risk clogging because the ink formula is not an exact copy of the genuine Canon formula. I recommend using only new Canon carts for replacement, and do not mix Canon with non-Canon carts.
You can find the replacement print head by Google searching "MP830 print head". Prices can vary from around $70 - $90. Changing it out is fairly simple. You only need to lift a lever that holds the head in place. Make certain that it is squarely seated, and then run a few pages of a color document, or do a couple of standard cleaning operations to "prime" the head.
Make sure the hed is NEW and not used or "refurbished". Here is one source on eBay that sells it for $78.00:
Nov 27, 2011 | Canon MP830 All-In-One Printer
Every cartridge prints except black. I have replaced the cart twice and still no joy.It shows as full on my computer. It just won't print.
Unfortunately, it's most likely that residual ink has dried and clogged the black print head. Plan on doing LOTS of cleaning cycles for the Black cartridge only if possible. It will consume lots of ink, so be prepared. After several cleanings and tests (as many as 10) you should see a gradually improving appearance of black. If not, try looking into the ink level counter to make sure it has reset to full as it shouls when you insert a new cartridge. If it is not, you sjould be able to change it. If that does not work, it's likely time for a new printer.
Apr 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Wont print black ink all outher colors ok cleand
If you did put in a new printhead, it means you need a new purge, or cleaning assembly. If it doesn't clean and prime the printhead properly, it won't print.
Dec 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
You print more documents then anything else, therefore you use more black ink, no color at all, assumption with information provided
Jul 16, 2009 | Dell 942 All-In-One InkJet Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
DCP 117C Brother ink jet printer: Although ink cartridge is filled, is showing black nearly empty error message. No black is getting through on test printing after head cleaning procedure.
two diffrent errors:
1. near empty. I guess your cart is at full level.: Take cart out. unplug dcp from power. leave scanner open. replug to power. machine will come up and demanding cart. insert cart. close cover. answer display if its changed!
2. press menu then start bk-copy then four times arrow up. machine will be in maintenance mode. press by help of arrow-up and set: 7 (set) 6 (set) 3 (set) start bk-copy. machine will do a power purge cleaning. when finished press 9 (set) 9 to leave maintenance mode. run a test print and set date/time again!
Apr 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
62 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
