Question about Panasonic SC-HT680 System
Can I bypass the dvd/cd player to use only the aux mode?
My panasonic SA-ht680' 5 disc dvd/cd changer is not working(kids somehow skipped some gears moving in and out of the player) and it has some unfinished buisness with disc three...etc. But all I want to do is bypass the dvd/cd player to use the aux inputs for surround sound etc, can i do that?
  • 514 Answers
SOURCE: Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Posted on Jan 11, 2009
smarthome2
  • 1114 Answers
SOURCE: CD/DVD PROBLEM ON A PANASONIC SA-HT680
Check your "Setup Menu" with NO DVD in the player. Could be the wrong format, should be 720p or 1080i or 1080p. Are you using Component cables to your TV or HDMI? if Component, check your connections, it is color coded but may be hard to see with most installations. Use a flashlight to make sure colors are correct Red to Red, Blue to Blue and Green to Green. Sounds like you've got cables mixed up. It happens to the best of us! and I do it for a living! Hope this helps
Posted on May 22, 2009
SOURCE: Panasonic SC-HT900-problems with surround sound mode and digital input
I have the same problem with my RCN system
Posted on Aug 27, 2009
SOURCE: I have a Panasonic SA-PT960 surround sound/dvd
Hi! the chgr err code indicates one of you trays is stuck inside the dvd tray unit. this occurs typically when the reader is initializing the last disk viewed and you push the exchange disk button. This happened already twice on my system. I did solve the problem by opening the unit and removing all components until I could access the trays and manually release the mechanism. I only recommend doing so if the player is out of warranty and if you are not afraid on working with small electronic/ components parts. I could not find any other non-invasive solution to the problem.
Posted on Aug 30, 2010
  • 910 Answers
There is a fault with the DVD Changer and the noise is the gears grinding. This is a common fault with these units as a small arm within the unit breaks and blocks the mechanism.
You can either try and replace the complete DVD Changer or remove it and just us it as a surround sound system with your auxiliaries connected to it.
Posted on May 09, 2011
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
DVD player not working.
Hello
The changer mechanism should be suspected. It is a skilled work to look into. You have to disassemble it. There are three microswitches inside the mechanism, which give signals of the state of the mechanism to main system control IC. If the loading gear wheels have some problem, these witches won't engage well, and the the whole mechanism will be inoperative.
Mar 04, 2012 | Panasonic Televison & Video
My SA-VK70D got F61 and imediatelly turn off..:(
i have vk70d and i have same problem .....your cooling fan not working ...chand it ...its work ....
Sep 03, 2009 | Panasonic SCAK410 5-Disc CD Changer
How do I clean 5 disk CD changer?
Laser Lens Cleaner. The same as any other CD or DVD player. Put the cleaner in position "1". Beyond that, there really is no other "user cleaning" necessary or reccomended. Unless the unit is "grinding gears" don't mess with it. Hope this helps
Jul 01, 2009 | Panasonic SCAK410 5-Disc CD Changer
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
The dog has eaten the remote control and now we can't input our code!
Try this. With no disc inside player, press and hold 'PAUSE', 'FWR SKIP' and 'OPEN' on player until INTIALIZED is displayed.
Apr 12, 2008 | Panasonic DVD-RV32 DVD Player
Panasonic SC-HT680 System Logo
160 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
