Question about Viking VGIC305-4B Gas Kitchen Range
Occasional gas smell
My 13 year old Viking 30" wide gas range will occasionally emit a gas smell when lighting the oven. I removed the kick plate and found the left burner will light 2 minutes after the right burner. Both igniters were replaced at the 6 year mark. The smell does not persist after about 10 minutes of both burners being lit. There is not smell at any other time.
Thnaks for any help.
Carl N
  • habu55 Jun 22, 2009
    The reply is not a solution. It is a warning. I am trying to determine how to fix the problem, not avoid the symptom.
  • 770 Answers
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Posted on Jun 21, 2009
  • Hal Hallman Jun 22, 2009
    Please understand the nature of your post. You are correct, my solution was a warning. You do have gas coming from the burner, otherwise it would never light. You have an ignition problem, a flame tube not properly aimed...something. You need, (for the safety of you and your family), a gas man come and assess the problem, or verify the fix. If I tell someone how to change a water pump, or install a dryer belt, hopefully my advice is good and they get their fix. But if what I tell them does not work, no one gets hurt. When I read your post, I offered the best advice anyone could give...leave it OFF. Had you called the gas man and given him the same info that I have, he would have told you to leave it off until he could get there to check it and make a qualified repair. Unfortunately, I cannot come and fix it myself, so I would be negligent and opening fixya up for a lawsuit if I offered a fix and for whatever reason it didn't fix the problem and your range exploded. I hope you understand.
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Jan 08, 2016 | Kenmore Elite 30" Stainless Steel...
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
My gas oven wont light
The ignitor that lights the burner has failed...
Checkout this tip that I wrote...it will help uou understand your problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 04, 2010 | GE Profile 30" Self-Cleaning Freestanding...
We have gas (we can smell it) on our Viking range and oven, However, the oven, oven lights and the burners are not working. Is this an electrical problem or what do we do to fix it. Thanks.
Can the gas company immediately if you are smelling gas in the home. Also locate the shut off valve, which is most likely behind the stove.
Jan 20, 2010 | Kitchen Ranges
11 year old Viking VGSU161-6BSS with intermittent gas smell.
STOP USING COOKTOP AND TURN OFF GAS AND GET SOMEONE AUTHORIZED IN AS SOON AS POSIBLE .
Oct 22, 2009 | Viking 37 in. VGSU161 Gas Cooktop
GE Model JBG280 new in Oct. 08 has a smell of gas leaking
Depending on how vented and the weather you could be getting some wafting, if concerned with a leak should contact your gas service person to come check. Make sure your vent isnt blocked. But I have found with most units in winter especially you can get the occasional smell due to wind directions , humidity. But please if over concearned get someone to check.
Feb 09, 2009 | GE 30" Self-Cleaning Freestanding Gas...
Oven does not heat up - occasional gas smell
you have bad ovne ignitors( bake iginitor is no good
Jan 28, 2009 | Amana ARGS7650SS Gas Kitchen Range
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Kenmore gas (propane) range Model #119.7488810 18-20 years old
you have a bad oven/bake ignitor, althoough you see ther glow, its not "hot" enough to allow gas flow or ignition, very common issue, 2 screws and 2 wires, probably about $75, service company gets min $225..
Oct 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Viking Range
I'm having a similar problem. I don't know the exact fix yet, I'm just starting to research. Check this link: http://www.applianceguru.com/forum1/1916.html
It sounds like the ignitors are suspect. This may be a weak component for Vikings. This link recommends a Maytag replacement part.
Dec 08, 2007 | Viking VGSC366-6B Gas Kitchen Range
Viking VGIC305-4B Gas Kitchen Range Logo
1,000 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
