Modern Fan Multi-Fan Speed Control Logo
Medard Mugarura Posted on May 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is FAN SPEED CONTROL? - Modern Fan Multi-Fan Speed Control
etrc_new
Level 3:
Master:
  • Master 752 Answers
  • Posted on May 02, 2014
etrc_new
Master
Level 3:
Master:
Answers
752
Questions
Helped
282853
Points
3763
What does it mean on a 2007 saturn relay shut off air condition for engine maintenance
It means you should take your vehicle to a qualified repair shop , at least that's the car makers thought .
A/C Off For Engine Protection
Refer to Cooling System Description and Operation
Cooling Fan Control
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) or engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 maxifuse?® through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation, the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 2 relay and the cooling fan relay through the high speed cooling fan relay control circuit. This energizes the cooling fan relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 maxifuse?® on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Are the radiator fans coming on ? You mite take it an have it checked for DTC'S - diagnostic trouble code's .
1helpful
When i start my 2008 Cadillac sts i get a notification that engine hot A./C off. Even though it is the first time i stated it today
ENGINE HOT - AC OFF
you must have a cooling system problem of some sort !
Do the cooling fans come on when A/C is switched on ? Fan's should come on ! Does your vehicle have two or three cooling fan's ?
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Cooling
Having a qualified professional technician check it out would be your best bet ! Hooking up a factory or professional type scanner an check data input's an DTC'S - diagnostic trouble codes .
Diagnostic Starting Point - Engine Cooling
Begin the system diagnosis with the diagnostic system check. Refer to Diagnostic System Check - Vehicle . The Diagnostic System Check - Vehicle will provide the following information:
• The identification of the control modules which command the system
• The ability of the control modules to communicate through the serial data circuits
• The identification of any stored DTCs and their status
The use of the Diagnostic System Check - Vehicle will identify the correct procedure for diagnosing the system and where the procedure is located.
DTC P0480: Cooling Fan Relay 1 Control Circuit
DTC P0481: Cooling Fan Relay 2 Control Circuit
DTC P0691: Cooling Fan Relay 1 Control Circuit Low Voltage
DTC P0692: Cooling Fan Relay 1 Control Circuit High Voltage
DTC P0693: Cooling Fan Relay 2 Control Circuit Low Voltage
DTC P0694: Cooling Fan Relay 2 Control Circuit High Voltage
DTC P1258: Engine Coolant Overtemperature - Protection Mode Active
DTC P2600: Auxiliary Coolant Pump Relay Control Circuit
DTC P2601: Auxiliary Coolant Pump Performance
DTC P2602: Auxiliary Coolant Pump Relay Control Circuit Low Voltage
DTC P2603: Auxiliary Coolant Pump Relay Control Circuit High Voltage
Fan is not working on 2001 Chevy Silverado 2500 truck radiator fan motor?
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Your best bet would be to take your vehicle to a qualified repair shop !
Relay Driven Dual Cooling Fan Diagnostics
2007 ford taurus condensor fan not coming on with ac
Fan Control The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure) to determine engine cooling fan needs.
For variable speed electric fan(s):
The PCM controls the fan speed and operation using a duty cycle output on the fan control variable (FCV) circuit. The fan controller (located at or integral to the engine cooling fan assembly) receives the FCV command and operates the cooling fan at the speed requested (by varying the power applied to the fan motor).
EDGE/MKX, FIVE HUNDRED/FREESTYLE/MONTEGO, FUSION/MILAN/MKZ, CROWN VICTORIA/GRAND MARQUIS, TOWN CAR: FCV DUTY CYCLE OUTPUT FROM PCM (negative duty cycle) FCV Duty Cycle Command (NEGATIVE (-) duty cycle) Cooling Fan Response/Speed Greater than 0 but less than 5% Fan off, controller inactive Greater than 5% but less than 10% Fan off, controller is in active/ready state Edge/MKX, Crown Victoria/Grand Marquis, Town Car:
10% - 90% Edge/MKX, Crown Victoria/Grand Marquis, Town Car:
Linear speed increase from 30% to 100% Five Hundred/Freestyle/Montego, Fusion/Milan/MKZ:
30% - 90% Five Hundred/Freestyle/Montego, Fusion/Milan/MKZ:
Linear speed increase from 50% to 100% Greater than 90% but less than 95% 100% Greater than 95% but less than 100% Fan off
For relay controlled fans:
The PCM controls the fan operation through the fan control (FC) (single speed fan applications), low fan control (LFC), medium fan control (MFC), and/or high fan control (HFC) outputs. Some applications will have the xFC circuit wired to 2 separate relays.
For 3-speed fans, although the PCM output circuits are called low, medium, and high fan control (FC), cooling fan speed is controlled by a combination of these outputs. Refer to the following table.
If you don't understand these thing's listed above your best bet is to take your vehicle to a qualified repair shop . Have the vehicle checked for DTC'S - diagnostic trouble codes !
If
I have an 05rendezvous,need to locate switches for cooling system,fans aren't co ming on & now I'm going to need a new radiator,cuz plastic broke.But it broke before fans gave out.Which I changed stat
The engine cooling fan system is controlled by the body control module (BCM) and the powertrain control module (PCM) or engine control module (ECM). The BCM performs the calculations as to how long, when and what speed the cooling fans should turn on. The BCM then sends a class 2 message to the PCM/ECM to engage the cooling fan relays. If there is a malfunction with the BCM, the PCM/ECM will control the engine cooling fans independently. The engine cooling system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM/ECM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 2 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 3 or S/P relay and the cooling fan 2 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The BCM and PCM/ECM command Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Important:: A 3 second delay occurs before the powertrain control module (PCM)/engine control module (ECM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Have two codes 1490 and 1489 what are they and how do i fix them
It's most likely low speed fan control relay circuit trouble.
There are separate relays and control circuits for high and low speed for the fans. This way if one messes up the other one should still work. Relays are in relay/fuse block under the hood. There is a diagram under the relay box cover that shows the function of each relay. The relays just plug in.
1489 = High Speed Fan CTRL Relay Circuit - An open or shorted condition detected in the control
circuit of the high speed radiator fan control relay.
1490 = Low Speed Fan CTRL Relay Circuit - An open or shorted condition detected in control circuit of
the low speed radiator fan control relay.
Either the relays are gone or the connector isn't plugged in, probably the connector if both the low and high circuit is out.
1helpful
I'm trying to find out how many cooling fan relays are in a 1999 Ford Taurus SE with the 3.0L Vulcan OHV engine. This model year has done away with the CCRM (Constant Control Relay Module), so the relays...
fuse #9 protects the 2 cooling fan relays.
It looks like the hgh speed cooling fan realy is in a thin box mounted sideways between the battery and fender.
It has high speed relay, autolamp relay, autolamp headlamp relay, horn relay, washer motor relay, wiper hi/lo relay, wiper park relay.
Section 03-03: Engine Cooling 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Electrical System NOTE: With A/C ON, the cooling fan motors will run continuously. Cooling fan motors will not cycle ON and OFF with A/C clutch (2884) .
NOTE: An exception to this is when vehicle speed is over 61 km/h (38 mph) and coolant temperature is below 100°C (212°F), and A/C head pressure is below 1.71 MPA (250 psi). The cooling fan motors will then automatically shut off.
The cooling fan motors are mounted within a fan shroud (8146) behind the radiator (8005) .
Engine Cooling Fan Control CCRM Applications The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure, etc) to determine engine cooling fan needs. The PCM controls the fan operation through the Fan Control (FC) output (single speed fan applications) or the Low Fan Control (LFC) and High Fan Control (HFC) outputs as shown in Table 2. Although the fan control (FC), low speed fan control and high speed fan control relays are normally open relays, the FC/LFC circuit is wired through a voltage inverter inside the CCRM. The voltage inverter ensures that the PCM must turn on (ground) the FC/LFC output to turn the fan off. This is done so the cooling fan will operate in the event of an open FC/LFC circuit.
Stand-Alone Fan Control Relay Applications The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure, etc) to determine engine cooling fan needs. The PCM determines engine cooling fan control requirements and controls the fan operation through the Low Fan Control (LFC) and High Fan Control (HFC) outputs (Table 3).
2answers
Antec fans connected to akasa fan controller, Speed doesn't change
Sounds like a problem with your fan controller. The controller is simply controlling the voltage applied to the fan to adjust the speed. Have you tried a fan without a speed control built in?
Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Top Modern Fan Dryers Experts
john h
Are you a Modern Fan Dryer Expert? Answer questions, earn points and help others
