Question about Mitsubishi WT-46809 46" Rear Projection Television
Wt-46809 has convergance issues
Bought this mitsubishi tv a couple months ago and have not had a problem until recently. The convergance goes screwy when the tv is first turned on. Sometimes it will correct itself other times I have to tap on the side of the tv for it to go back to normal, but it is getting worse. Is there anything I can do to fix this? Thank you for the help!
  • 668 Answers
Replacing the Convergence IC's should do the trick. But it is not a easy repair do to the disassembly requierments. I would recommend calling Mitsubishi at 18003322119 to get a local service facility to come out and give you a estimate to repair.
Posted on Jun 22, 2009
I have a 2-2 error code and tv shuts off after a couple seconds any ideas?
Thats almost always caused by a shorted convergence circuit. Installing a convergence repair kit will usually solve that issue. You can get the convergence repair kit for that model which contains the parts and the CD with repair instructions from www.tvrepairworld.com
Feb 17, 2012 | Mitsubishi WT-46809 46" Rear Projection...
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
Jul 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Convergence
hello theres a couple of codes you can try .1-2-7-0/2-4-5-7/0-3-5-3 /0-3-5-7 do not use the reset it may cause damage ti the tv good luck
shaun
Apr 10, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 not turning on
Your convergence amp ICs have most likely failed and that will shut the TV down. You need to replace both convergence ICs they are both STK392-570 you can get replacement ICs with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jul 18, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi TV
the fluid in the crt lens leaks onto the circuit boards..check for any wet areas or any gooey globs on the boards
Nov 27, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Intermittent color problem
I have the MITSUBISHI WT-46809 46" HDTV CONVERGENCE IC PROBLEM as well. I just ordered the STK392-570 IC for 7 bucks and I am going to attempt to switch them both out (two of them). I am getting the overstated "bow tie", "RBG separation" issue that you are talking about. I am going to attempt to de-solder the intergrated chips and put new ones in. I figure it is worth the shot, insted of paying 350-650 bucks to have some **** with average skills do the same I figure it is better to have this **** with average skills do it and keep the cash. I will let you know how it goes.... DJ
Feb 24, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Picture on my WT-46809 not centered
How much did they charge you to do it? I am going to replace them myself....just wanted to see how much I will save. DJ
Dec 17, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
342 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
