Question about Toshiba TN50X81 50" Rear Projection Television
No Picture The red power light is flashing and I can't turn unit on
    Sergeant:
  • 296 Answers
Hi
A power regulator or a sweep power supply problem. The power regulators in the main power supply, and will have or start with STR###-## The # are numbers or letters. This is a repair that should be done by an amature or layman. This is a solid state set, and there are no user replaceable parts inside these sets. Have it looked at by a trained tech.
From your description, I suspect you have a power supply problem. It sounds like set is turning off because the power supply is not regulating properly. I would suspect you have a few Capacitors in the regulator circuit failing.
If you were to take this set into a shop for repair, I would expect the cost to be around $150.00 to fix it.
If you are going to look at it yourself. I would look for bad caps in the regulator section
If you are going to work on this yourself, I would recommend finding someone with television repair experience and the proper test equipment to help you. Television picture tubes contain, High voltage. You can be shocked even it the set is unplugged If the tube is not properly discharged.
hope u will b helpfull
regards
Posted on Jun 21, 2009
  • Anjana Batabyal
    Anjana Batabyal Jun 21, 2009
    The flashing light indicates a diagnostic state called protection.
    When the TV goes on protection there are only two possible reasons.
    1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
    2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
    If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
    If you are in situation 2 , then there is an internal fault.
    Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
    Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
    regards
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDS-60A3000 won't power up 9 flashing red power light
According to other posts I have read (I have same problem) there is no power getting to the fans. They recommend re-seating the fan harness again as it might have come loose or might have dust etc., in it.
I have no idea how to do this yet but that is what the trouble-shooting guide says.
Feb 25, 2009 | Televison & Video
Flashing red light
If the unit does not even turn on, thats a power issue. You need to contact sharp and let them set u up for repair. I hope you still under warranty.
Nov 28, 2008 | Sharp Aquos LC-32D40U Television
42" Panasonic plasma has no picture, but power light is flashing
I think accroding to your model number this unit is plasma.
I need to know red light how many times flashing and correct model number
Sep 18, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
May 31, 2008 | Sharp XR-10X Multimedia Projector
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
No picture
When you turn it on if you haer a high chirp chip befor the light turns red
starter ok lamp has reach its life needs to be replcce
Mar 04, 2008 | Canon LV-7210 Multimedia Projector
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba TN50X81 50" Rear Projection Television Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
