Question about Panasonic KV S2026C Path-Through Scanner
Failure to Create a New File
Panasonic KV-S2026C
I am getting an error message when attempting to scan documents. The message is: Failed to create a new file (Code: 40000006)
  • 3 more comments
  • ray0580 Jun 21, 2009
    It didn't work.
  • ray0580 Jun 22, 2009
    There are no applicable software updates.
  • ray0580 Jun 23, 2009
    Please see Solution 3. I tried that procedure and it didn't work. Solution 2 also failed to work.
    I can't find the "link below" you refered to in your last response.
  • ray0580 Jul 05, 2009
    Bfas1:
    In response to your question as to whether or not the scanner is working. Yes, it is working. I've connected it to my laptop and it works fine; however, it has stopped working on my PC. It is obviously a software issue.
    President:
  • 828 Answers
Th problem is "Failed to create a new file (Code: 4000006), here is a tip & solution.
I'm sure you install properly the software of it... If you going to scan some documents and pictures, use Adobe Photoshop CS to run your Panasonic Scanner on it... And Check the driver of your printer "Twains" software. Good luck!
Posted on Jun 24, 2009
  • 258 Answers
I am very experienced with printers and this normally means that you don't have all the drivers you need to transfer the scanned document to your computer, it must be the usb type so click the link below to get the drivers need for proper communication between your printer and pc, please note though when clicking on the link, when the website opens up scroll down to where is says driver download and follow the instructions there, this should solve your problem after you install the driver, follow the instructions futher down the website to install correctly, if you complete this and you are still having problems let me know, I will stick with you till its resolved.
Posted on Jun 23, 2009
  • Brett McGuigan
    Brett McGuigan Jun 23, 2009
    ok i have to brain storm going by my knowledge, please let me know if any of the questions below exist...........
    Ok is the scanner actually working, can you hear it working?, can you seen light coming out from under the bed lid as it is scanning if you slightly raise the lid a little?, is the usb lead that goes from the computer to the printer in the usb port of the computer properly and in the printer properly?, make sure all this is secure and working, is the computer detecting the printer?,
  • 854 Answers
Panasonic includes a user utility with this model. The utility can be accessed via Start>All Programs>Panasonic. In it you will find a display and reset function for the cleaning count.
    Top Expert:
  • Panasonic Master
  • 81,294 Answers
Go to the scanner web site and check for updated software, every scanner i have had has had some type of problem like this until i downloaded and installed all the latest software and system "fixes"
Posted on Jun 22, 2009
    Genius:
  • 1,847 Answers
This utility can be accessed via Start>All Programs>Panasonic.
That should make it work fine
Let me know
Thanks
Kevin
Posted on Jun 21, 2009
Kv-s2026c paper jam
Are you just receiving paper jam message or paper is actually jammed in the unit.Or the paper is getting jammed every-time while getting the printout.Click this link below :-----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 26, 2012 | Panasonic KV-S2026C Pass-Through Scanner
KV-S2026C not scanning
does this unit show any error?
how old is this unit> is it under warranty?
Oct 02, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Auto crop and Deskew ?!! everytime i try to scan it pops up with a message saying...these settings will be ignored: -autocrop -deskew we have to scan document that are really long and i cant have it...
I know this is very old and you have probable answered your own question, but in case anyone else finds this...
Search google for panasonic reference area/roller, they are two rollers inside your scanner, if they are set to white Deskew and Autocrop amongst others will be disabled, if its set to Black they become available, I spent two days trying to sort this.
Oct 19, 2011 | Panasonic KV S2026C Path-Through Scanner
My panasonic kv-s2026c has a black line running down the left side when I scan my documents. I have cleaned the rollers, used air canister to see if anything is stuck in there. That didn't help
On the CD that came with the scanner is a directory called "Shading Utility". Copy this folder to your PC. Put a blank piece of copy paper into your scanner. Open up the Shading Utility folder and then double-click on the shadingutility.exe. The password is "GOSHADING" without the quotes. This process will take a few minutes but it will re-align the lens in the scanner which has gotten out of alignment through vibration. This is what is causing the vertical black line on the left side of the page.
Jan 13, 2011 | Panasonic KV S2026C Path-Through Scanner
Line in scanned document
Its dirt! It takes just one tiny speck of dirt on the lens to make a vertical line.
We have some scanner maintenance videos;you want to clean the CIS front sensor.
Regards,
MyEfact
May 12, 2010 | Panasonic KV-S2026C Pass-Through Scanner
Trying to scan I get the error message ''A Sharing violation occur
Create a new windows user account .Try to scan the document in the new admin user account.
Aug 17, 2009 | Lexmark X5495 Printer
Yellow light is blinking and error indicates clean rollers. Rollers have been cleaned but message keeps coming back. No problems scanning.
Panasonic includes a user utility with this model. The utility can be accessed via Start>All Programs>Panasonic. In it you will find a display and reset function for the cleaning count. Sorry I don't have more specifics, its been a while since I worked on any Panasonics.
Apr 06, 2009 | Panasonic KV S2026C Path-Through Scanner
Just check if you have enough disk space in the location where you are directing the computer/Scanner to store scanned images.
S. Mohan
Feb 20, 2009 | Panasonic KV-S2046C Pass-Through Scanner
Scan only in jpg.
If you want to scan in TIFF, you need to scan in monochrome only. (B&W). Change SCanner settings.
S. Mohan, Chennai, India
Feb 05, 2009 | Panasonic KV-S2026C Pass-Through Scanner
Panasonic KV S2026C Path-Through Scanner Logo
168 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
