Question about Home Theater Systems
Panasonic SA HT 500
Have got home today from work and both red lights are on, one on the system and one on the woofer, but can't get the display to light up. Does any one have any ideas? I have a SA-HT830 that has the same problem - the display does not light up. Everything else seems to be OK and working, but nothing on the front panel display shows up. Can anybody help with this, please?
SOURCE: Panasonic SA HT 500
displays error "HO2"
Posted on Jan 31, 2010
0 characters
1 Points
My panasonic sa-ht70 led stop displaying . Everything else seems to be operating fine.
The front board will need to be replaced. The front board has the buttons(i like the touch buttons in the Samsung HT-Z320) and te display.
Jun 23, 2010 | Panasonic Home Theater System System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Dec 12, 2009 | Panasonic Home Theater System System
Panasonic Home Theater system SA-HT 1500
Not sure this will work for you, but it did for me. Really simple. Unplug the unit for 5 minutes. Started right up.
Sep 10, 2008 | Panasonic Home Theater System System
Panasonic sa-ht 530
hello.i've got a problem with my home doesn't start .the light is stay red and the system is not starting ,.
Jun 04, 2008 | Panasonic Home Theater System System
Unlock code for Panasonic SA-HT 340
i have the same problem .. somebory can help us? thanks
Jan 05, 2008 | Panasonic sa-ht930 Home Theater Audio...
Connecting ipod
Yes you can connect your i-pod to your sa-ht 930. You can buy a connection at Walmart for $5 bucks or you can go to Tareget and buy a monster connection for about $25 bucks. I bought the monster connection and works great. All you have to do is connect it to the AUX in the back to the white and red jack in put. Once you connect it change the input selector to AUX and you're ready to go.
Dec 08, 2007 | Panasonic sa-ht930 Home Theater Audio...
SA-HT800V Home Theater
Check that the woofer cable is not shorted.
Oct 06, 2007 | Panasonic sa-ht800V Home Theater Audio...
Home Theater Systems Logo
478 people viewed this question
Top Home Theater Systems Experts
Gyula Lacz
Are you a Home Theater System Expert? Answer questions, earn points and help others
