Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
My jenn-air self cleaner has been on for aboiut 4 hours so I turnrd it off. Now I can't get the oven unlocked. This old model has no "display" to give me any info.
    Genius:
  • 1,847 Answers
Yes you can, many a times just by unplugging and replugging back works. Else try the following.
  1. Step 1 Check to make sure that the Jenn-Air oven's digital display still shows "Lock" or "Off." If neither of these messages show, the oven is not locked and requires no further effort to unlock it.
  2. Step 2 Wait for the oven to cool completely, if it has been on the self-cleaning cycle, before attempting to unlock or open the oven door. It will automatically unlock once the oven has cooled, which may take several hours depending on the temperature of the cleaning cycle.
  3. Step 3 Press and hold the "Cancel" and "Cook & Hold" buttons on the oven or, if you have dual ovens installed, the upper oven. This will reverse a manual locking of the oven door.
  4. Step 4 Wait until the message "Lock" flashes on the digital display, then release the buttons. Your oven is now unlocked.
Thanks
Kindly rate the answer
Kevin
Posted on Jun 21, 2009
After self cleaning process oven door would not unlock replaced display panel F3 error fan runs constantly lower unit still works upper unit still will not unlock
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 04, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
    Thank you and thanks for using fixya
    Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
    Jenn-Air stove locked
    After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
    Dec 10, 2008 | Ovens
    No digital display oven works
    We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
    Steve Patterson
    303-256-8494
    stevieb4019@comcast.net
    Nov 21, 2008 | Jenn-Air JJW8527C Expressions Collection...
    How long should the self cleaning oven run?
    I don't have a Jenn Air, but I leave my self cleaning on for about 40 minutes.
    Dec 21, 2017 | Ovens
    Jenn Aire lock for self clean in locked position
    The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
    Do NOT force the door.
    Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
    Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
    Lever open, set the knobs to OFF and away you go
    Oct 26, 2008 | Jenn-Air Ovens
    Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
    50 people viewed this question
    Top Kenmore Ovens Experts
    Marvin
    Marvin
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
