Cars & Trucks Logo
e
emma Posted on May 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Audi a3 99reg and the speedometer is no longer working but the rev counter and all other gauge s r working fine what could be the problem????
ARESTI
Level 3:
  • Audi Master 1,152 Answers
  • Posted on May 02, 2014
ARESTI
Audi Master
Level 3:
Answers
1152
Questions
Helped
362188
Points
3284
Check if your speedo counter is mechanical the is the cable either broken on the gear box side or behind the dash. If is an electronic one then check the electronic speed sensor on the gear box.
Good Luck Emma !
  • Deana T
    Deana T May 04, 2014
    Hopefully it is a sensor and not the actual speedometer. To replace the speedometer you will have to buy the entire instrament cluster. A remanufactured one use to run over $1000. One of the few if not only place that is able to repair Audi speedometers is at "2 Bennett Audimotive" 5080 Chiles Road Davis, Ca.(530) 758-7325 www.2bennett.com (It is just west of Sacramento). My husband was an Audi service advisor for 13yrs. I hope this help you.
ttr49
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jun 19, 2014
ttr49
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
3116
Points
15
Have parts store check engine control module for codes. If you have code p0700(trans control module). then likely output speed sensor. If not then likely poor circuit board contacts on instrument cluster.
5 Related Answers
DaveBob55
  • Posted on Jun 15, 2008
SOURCE: Fuel guage and Temperature guage
My 06 ranger is a 4 cyl model and I also am looking for a wiring diagram. Have you checked bulkhead connectors on the firewall for security, corrosion etc.? If you find the schematic on line please post the link. Good luck.
DaveBob55
Anonymous
  • Posted on Jul 21, 2008
SOURCE: vw polo 1997, speedometer
thats exactly what it is, loose grounds. don't bother getting another from a junk yard because it will most likely have the same problem or will eventually do the same thing. Took mine out soldierd the grounds at a few places and has worked ever since. Now if i could just get the stupid a/c to stay on!
Anonymous
  • Posted on Dec 08, 2008
SOURCE: speedometer and odometer not working 92 audi 100
I had similar problems with speedos in two 1990 Audi 100s, it was some time ago, but the contacts on the circuit boards on the back of the speedo deteriorate and do not give a good contact. I bought second hand speedos, only to find they had similar problems, eventually it was very easy to fix, I shaved matchsticks to chisel points and pushed them into the circuit boards to add pressure on the contacts and improve connection. After that repair drove the cars for a few years and the problem did not recur. It was a long time ago and I cannot remember exactly where the matchsticks were placed but look for soldered points near the edges of the boards. Regards, Michael
ROB
  • 858 Answers
  • Posted on Jul 20, 2009
SOURCE: speedometer not working but all other instruments
speedo drive sensor on transmission failing or loose or dirty connections
Anonymous
  • 76 Answers
  • Posted on Feb 08, 2010
SOURCE: Instrument panel on my vauxhall astra does not work
i think vauxhall used the canbust system on this car and you cant cut into the wiring m8 you can buy a repair kit from internet but it might be expensive
I have a jetta 3 ,when I start the car,and do some revving the speedometer goes up instead of the rev counter..can anyone assist me with that
Volkswagen
ever see the cars cluster work right ever???????????
no VIN told, at all
no year or engine told or tranny and all are part of VIN.
. jetta 3 ,1995 first one USA are you USA? not told.
aka
Third generation (A3, Typ 1H; 1992-98) RPM gauge. tachometer.(slang rev counter) sure.
not told what gear car is in nor if A/T or M/T box
auto or manual box. WHEN IT FAILS.
is the box in neutral or park,
and??this?
"done over?" means overhauled or a tuneup simple.
if in DRIVE say so
if RPM a gauge called a tachometer that is dead all the time say so. in drive or neutral
yes RPM comes from the PCM. via CKP sensor or CMP x2. derived.
the speedo uses VSS sensors. veh speed.
no vin ,no JOY
got ABS?
My audi 2.0 tt has electric faults ie the rev counter and speed counter dont work. The handbrake light and the steering light stay on Can you help please?
U MIGHT NEED TO CHANGE THE INSTRUMENT CLUSTER......ONLY AT THE DEALER.....HERE IT COSTS A LOT..ASK UR LOCAL DEALER AND LET ME KNOW...
Why are my Bravo dashboard instruments not working?
When the battery is not working ( flat -dead or removed ) it affects the CPU program which affects various operation such as what you describe . Mostly it can be fixed by the removal of the earth wire but to do the job properly use a scanner to reprogram the CPU.
Audi speedo,rev counter,fuel geuge and temp stoped working
Fuse for instrumntnpanel blown or needs re-seating
2004 Ford Fiesta speedo (and rev counter) works intermittently.
vehicle speed sensor at transmission or bad wires/loose connector
2answers
The display between the speedometer and rev counter doesnt work. Its the display that shws you your range and if any doors are open. It comes on after driving for about 20 mins. AUDI Q7 2006
cost more to fix than its worth ,its a new speedo head or BCM and will cost around 300 euros just for th head without fitting and programming
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
