Question about Bernina 1008
How to i thread my 008d bernina serger? - Bernina 1008
If you need addtional help email me @ icando@sonic.net I'll help you. I have the same serger. I like it. You probably will to once you've figured it out. Although I don't know anyone that has that model beside me and a Bernina Dealer.
Posted on Jul 10, 2009
    Problem Solver:
  • 5 Answers
I believe it is color coded right?
start with the Upper looper follow from the upper looper throught the loops below the machine up through the tension disk and to the place where the thread cone sits. now retrace your steps from the thread to the looper place thread under foot.
by starting from the finishing point to the starting point you know where you are going with the thread when you thread the machine so upper looper lower looper right needle left needle. you must get it exactly correct or it wont work
Posted on Jun 21, 2009
What tensions should I set my White Speedylock 234DE Serger on, please?
Manipulating the tensions on a serger creates the different stitches. Therefore, it depends what stitch you want to make that determines how you set the tensions. For a basic 4-thread overlock, usually setting the tensions at the midway point is standard, however, some tweaking of each may be required to get them balanced. What helps is to thread with four different colors making it easier to see which thread's tension needs adjustment.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
You can download the Bernina serger workbooks that may help you set up your machine for specific overlocker stitches:
Bernina Mastery Workbooks
May 12, 2018 | Sewing Machines
I would like a diagram of threading help that is big enough to see, for Bernina Serger 2000 D , NOT 2000 DE. Or maybe I have just BERNINA 2000. Please. I have the manual. JOELLIE@SHAW.CA
http://www.bernina.com/de/SupportData/Out-of-Print-de/BERNINA_Serger_2000_manual
If you view the book online, you can usually enlarge the view.
Easy Instructions for Threading Bernina Serger eHow
Start out with NO thread in the machine.
ALWAYS RAISE the presser foot during the threading process.
When threading through the tension guide below the thread tree and through the tension disk, give each thread an extra little tug to make sure it is completely seated (it may even make a little popping sound when it seats).
ALWAYS THREAD each IN THE CORRECT ORDER (upper looper first, lower looper second, then the needles). When threading the lower looper, ALWAYS FINISH with the lower looper thread draped OVER THE TOP of the upper looper.
If a serger looper thread breaks, it is most often easier (and much less frustrating) to unthread the entire machine and start from the beginning. Trying to fish a thread through only works about 1% of the time, Just bite the bullet and do it!
When unthreading the machine, NEVER pull the thread UP through the tension disks! Instead, cut the thread below the thread tree, RAISE the presser foot and pull the cut threads down and out.
The Bernina Serger Workbook may be helpful, found here:
http://www.berninastore.com/workbooks.htm
Jun 15, 2017 | Bernina Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
How do I thread the Bernina Overlocker
Depends on your serger model. Best idea is consult the owner's manual. Some manuals are available for download on Bernina's web site (look under Support). Be sure to thread in the order specified in the manual. Usually the upper looper is first, then the lower looper second, then the needles. (Hint: The lower looper thread ALWAYS lays over the top of the upper looper thread in the final looper threading step.)
You can also download a serger workbook too.
BERNINA of America Premium Swiss quality sewing machines BERNINA
Aug 25, 2015 | Bernina Sewing Machines
Need manual for bernina serger 1300dc
I have a Bernina Overlocker/serger 1300DC having trouble threading the machine
Sep 23, 2009 | Sewing Machines
I have a Bernina 800 Serger and I am trying to thread it.
You might take a look on ebay item 150416413591
Sep 07, 2009 | Bernina 1008
Threading a bernina serger
Here is a little jingle to remember as far as the order of threads to thread...
Upper looper, lower looper, left needle, right.
Usuall if you give numbers to the threads from left to right as 1,2,3,4 , you would thread it in the order of 3, 4, 2, 1 . Also when threading the loopers be sure the lower looper thread goes over the top of the upper looper thread as it goes out the back.
Hope this helps.
Sep 02, 2008 | Bernina 1008
Sewing Machines Logo
390 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
