Question about Gateway (5500652) (  5500652) DVD Drive
My optiarc DVDRW AD-7563A ATA DEVICE dose not work. Tried uninstelled and reboot still no/go.Help anyone
    Problem Solver:
  • 10 Answers
Open the set up
re connect the wires connected to ur drive as previously
re boot the system
hope that works
Posted on Jul 09, 2009
My dvd does not play error 10 device manager and yellow sign optiarc dvd rw ad 7563a ata device
Is this an internal or external drive? if it is an internal one then on the device manager screen where it is hows the yellow sign on signoptiarc dvd rw ad 7563a ata device, right click on that an click on uninstall.....And if any pop up comes up click on ok and restart the pc after that. Wait for the pc to reinstall the driver for the dvd drive. And then check the status of the dvd drive on device manager. If it does not have any yellow sigh then try again.
Feb 17, 2011 | Gateway (5500652) (  5500652)...
My optiarc dvd rw ad-7563a ata device cant read dvd disk but it can play cd's ony
try re-installing deice driver....if do not work...replace the drive.
Sep 13, 2010 | Gateway (5500652) (  5500652)...
My Optiarc DVD RW AD-7530B ATA Device does not detect any discs
To delete the offending keys, open the Registry and navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***\{4D36E965-E325-11CE-BFC1-08002BE10318}. . Delete the keys named UpperFilters and LowerFilters and reboot.
Oct 30, 2009 | Microsoft Windows Vista Ultimate Edition
Gateway M-6848 arrived with vista home. used
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 14, 2009 | Philips (JR4DVDRWK/00) DVD+RW Burner
Optiarc DVD RW AD-7563A ATA Device will not play cd's/dvd's My device used to work good, but suddenly it stops working. It doesn't do nothing at all, doesn't burn a cd or dvd, but either read it. And in...
If the drivers have been updated recently, go to the properties page for the device and click on the Rollback drivers button. Reboot the machine and try using the drive again. If that does not work, you can go into Device Manager, right-click on the drive and select uninstall. Reboot the machine and it should re-detect the drive and reinstall the proper drivers.
Jun 01, 2009 | Gateway (5500652) (  5500652)...
It seems to be a common problem on the gateway systems. To correct this you need to go into your Registry Editor. Go to HKEY_LOCAL_MACHINE/HKLM\System\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} When you click on {4D36E965-E325-11CE-BFC1-08002BE10318} look in the right side box. You should see an entry labeled UpperFilter delete this entry. You may also have a LowerFilter if so delete this as well. Exit Regedit and reboot. This solved the problem for me.
Apr 25, 2009 | Gateway (5500652) (  5500652)...
My optiarc dvd rw ad-7173a ata device is not wokin
check ide cable in motherboard and jumper setting
Mar 18, 2009 | eMachines T5274 Desktop PC
Open Questions:
iTunes can no longer find my CD burner. Using a gatewayM-1631U laptop, with windows 7 x 64 home premium edition. (See additional details below). I use iTunes regularly, and as recently as Xmas 2009 was burning music CDs frequently on my laptop. Yesterday I attempted to burn a CD, and iTunes no longer recognizes the installed CD burner. I have not installed any programs to my computer recently, or made any other changes. Today I began investigating the issue. I have tried (not in order) the following - and have not solved the issue: 1. Going to the registry editor and deleting the lower and upper filters associated with the H_KEY_LOCAL MACHINE/SYSTEM/CURRENT CONTROL SET/CONTROL/CLASS 4DE3695 .... 2. Uninstall and reinstall iTunes (9.0.2.25) 3. Repair iTunes 9.0.2.25 4. Looked for updates for the drivers (can't find any) 5. Downloading Gearsoft products I admit that I have not tried Windows Media Player (because I'm committed to my iTunes - I sync with my ipod all the time and listen to it alot). I also realize I may have made the problem worse by some of my attempted fixes. Here is the information gathered through itunes diagnostics: Microsoft Windows 7 x64 Home Premium Edition (Build 7600) Gateway M-1631U iTunes 9.0.2.25 QuickTime 7.6.5 FairPlay 1.5.23 Apple Application Support 1.1.0 iPod Updater Library 9.0d11 CD Driver 2.2.0.1 CD Driver DLL 2.1.1.1 Apple Mobile Device 2.6.0.32 Apple Mobile Device Driver not found. Bonjour 1.0.6.2 (118.5) iTunes Serial Number 2987488CE609EDAB Current user is not an administrator. The current local date and time is 2010-02-05 07:50:22. iTunes is not running in safe mode. Video Display Information ATI Technologies Inc., ATI Radeon X1200 Series **** External Plug-ins Information **** No external plug-ins installed. iPodService 9.0.2.25 is currently running. iTunesHelper 9.0.2.25 is currently running. Apple Mobile Device service 2.50.39.0 is currently running. **** CD/DVD Drive Tests **** No drivers in LowerFilters. UpperFilters: GEARAspiWDM (2.2.0.1), Failed while scanning for CD / DVD drives, error 2380. Error while opening iTunes CD driver. This could be caused by a corrupted iTunes file or a conflict with other older CD burning applications, either currently installed or previously installed and uninstalled incorrectly. Additionally, the device driver says my DVD/CD unit is: Optiarc DVD RW AD-7563A ATA Device Anything else you need to help me figure this out? Could really use help and advice. Thanks in advance.
Feb 05, 2010 | Gateway (5500652) (  5500652)...
See all Gateway (5500652) (  5500652) DVD Drive Questions
Gateway (5500652) (  5500652) DVD Drive Logo
510 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
