Question about Delta 10"Hybrid Tablesaw with 30"Unifence
Delta Table Saw stopped running
Delta Table Saw model 1313314 stopped running. the reset switch does not solve the problem. won't turn on at all.
  • Anonymous Mar 17, 2014
    On/Off switch not woking for Delta Saw 36-650
    Problem Solver:
  • 9 Answers
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Posted on Jun 22, 2009
  • Bob Mayfield
    Bob Mayfield Aug 13, 2015
    If it has a magnetic switch, the simplest solution is that you have an intermittent break in the circuit. Redo the plug wiring first. It costs nothing. After that you have to start testing and replacing parts starting with the contactor relay and/or perhaps the thermal breaker.
Where can I find a motor for a Delta 36-3200 table saw?
notify manufacturer--electrical shops --online search
Jun 13, 2018 | Delta Saws
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Delta 1313314 motor runs but blade doesn't turn
With this perticular motor I would suspect that the issue is a broken drive belt. The belt is located on the back side of the motor, behind the plastic end cap. The belt is a 10" long cogged belt and looks like a timing belt.
Jan 20, 2012 | Delta Saws
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
I have a delta 36-600 table saw that the clutch or drive has quit working . the motor was rebuilt about a year ago now the drive slips is there a simple or easy fix or adjustment to the clutch for this...
If you have a motor with the no.1313314 and the motor runs ,but the blade spindel does not turn try removing the backcover plate . With this removed you might find that the toothed gear belt has broken. If this ,in fact, is the problem the belt is a Bando syncro,link 100xl.
Hope this rectifies your problem as I am waiting for a new belt myself.
E
Oct 10, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Where do I find a replacement motor for a 1313314 Delta table saw? Wont take a load, keep turning off and smells hot?
Hi there
You can try the website @ http://www.deltaportercable.com/ to see parts list and find service centers near you .
Delta , Porter Cable and Dewalt are together so you can get parts thru Dewalt parts center .
Hope this help
Aug 31, 2009 | Saws
I was using my Delta TS220LS table saw and it stopped running.
Confirm there is power to the plug that you are using to power the saw.
Reply back your finding and I can help you further.
Jan 07, 2009 | Saws
Delta 10"Hybrid Tablesaw with 30"Unifence Logo
1,266 people viewed this question
Top Delta Saws Experts
Craig Butler
Craig Butler
Ronny Bennett Sr.
Ronny Bennett Sr.
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
