take out phillips screw by lint screen. pull top panel towards you, lift top. remove two 5/16 inch screws on inside of front panel. undo door switch plug on right side at top of inside panel. pull panel up and remove. to remove belt push tension pulley to right and pull belt off. reverse to put back together
Comments:
Jun 21, 2009
- take out phillips screw by lint screen. pull top panel towards you, lift top. remove two 5/16 inch screws on inside of front panel. undo door switch plug on right side at top of inside panel. pull panel up and remove. to remove belt push tension pulley to right and pull belt off. reverse to put back together
My dryer shuts off before the timer is done. And when you set the timer you can't hear it...
(More)
My dryer shuts off before the timer is done. And when you set the timer you can't hear it "tick". The dryer does not work at all now.
Kenmore comercial electric dryer makes buzzing noise and won't restart after you open the door until...
(More)
Kenmore comercial electric dryer makes buzzing noise and won't restart after you open the door until you put more money in. Buzzing kinda reminds me of a motor starter problem but i couldnt find a starter.
I have a Kenmore 70 series dryer that wont heat. I've already replaced the igniter, not sure what...
(More)
I have a Kenmore 70 series dryer that wont heat. I've already replaced the igniter, not sure what else it might be?
when i push buttons nothing lights up and nothing happens. it is a kenmore, and around 5 years old....
(More)
when i push buttons nothing lights up and nothing happens. it is a kenmore, and around 5 years old. it isn't the circuit breaker, because it is the same breaker that runs the microwave and the microwave works.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
