Question about Acer AL2017 20" LCD Monitor
Monitor turns on then split second window displays and goes dark
    Novelist:
  • 152 Answers
You may need to change your desktop resolutions, they may be out of range for your monitor.
you may need to swap the monitor to perform the actions
Posted on Jun 21, 2009
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
When I turn monitor on, it stays on only 2 seconds, then goes dark. When I turn the monitor on, it lights for another two seconds, then goes dark. It is a MAG Innovision TCO 03 display. Thank you!
It could be two things. 1). The video card is set to a resolution the monitor does not support. 2). The monitor's power supply is bad. You can try to boot into rescue (or "safe") mode, and adjust the video card to a resolution the monitor supports. OR, power supplies usually go bad because capacitors bulge or otherwise go bad. Most monitor power supplies are hard to get, so people typically repair them. If you disassemble the monitor shell, you can see the power supply (where the AC cord goes). You can look at the metallic, cylindrical looking things with minus signs down one side, and if they look bulged on top, you can replace them. You can get replacements at mouser.com.
Mar 30, 2013 | Mag Innovision 19" LCD Flat-Panel Monitor...
Our monitor just recently stop working correct. It is on fine during boot but once Windows starts up, the screen goes dark after about 2 seconds. If you turn it off and back on, we get a screen again for...
try reinstalling the os.
there might be file corrupted in the system folder,,,
since the monitor runs on start up , we cannot say that it has a hardware defect...
reinstalling or upgrading your windows will help..
Mar 11, 2010 | Microsoft HannsG HU171D 17" LCD Monitor
My monitor showes for a split second then goes black
First, can you attach another monitor to the computer to check to see if it works?
If it does, then your monitor is going bad. Possibly the power supply.
If a second monitor acts the same way, then it's your video card.
Dec 10, 2009 | Computers & Internet
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG L1717S has no light
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
SCREEN GOES DARK TWO SECONDS AFTER ITS SWITCHED ON
when it goes dark disconnect the data cable of the monitor from the system end and if u still see nothing
monitor bad and if u see the colour scheme monitor working system is the culprit
Oct 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Acer AL2017 20" LCD Monitor Logo
408 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
