Question about Zyxel (91-004-361002) Wireless Router
Lose router signal everytime i restart my laptop
I have a brand new HP laptop that picks up every wireless signal around me except the one from my own router. As soon as I go to the wired pc, log into the router and configure the security settings without changing anything and the router reboots, the laptop picks up the signal and automatically connects. It just wont pick up the signal upon restarting until I reboot the router again. The router is a brand new D-link. This is driving me crazy! Please help...
  • 1,272 Answers
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Posted on Jun 22, 2009
LENOVO G780 WiFi problems
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 02, 2013 | Lenovo G780 2182 laptop
My compaq presario v2000 laptop cannot detect the wifi signal of Zyxel router. It can detect all other router brands. I'm sure that my Zyxel router is sending signal because I can detect it using my...
I would guess that all the other wireless routers are broadcasting using the G wireless standard 802.11g and your router is only broadcasting using the newer N 802.11n standard. Your laptop only supports B/G. Check your settings on your router and either change it to G or dual G/N mode so your older laptop can find the network
Sep 17, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
My laptop (hp window xp) can't connect to the wireless internet ??? It won't even let me type the password. Everytime when i click on it, it starts connecting. but before the password typing comes, it says...
you have problem with router range your laptop has been not get proper signal from the wireless router when got signal you get password screen then after due to signal is week the connection will lost
Nov 13, 2009 | HP Pavilion dv9000z Notebook
D Link Wireless N router keeps having to be re-set
I've seen this on a router that was broadcasting very little signal. (in my case the next day it died. When the laptop is running move away from your router and try to determine where it loses signal strength. A router is good from the factory for about 200 feet with no obstructions. In most homes I give them 30 to 40 feet. Be aware that windows and glass doors nowdays use a metal mylar film between the glass to reduce infrared rays. If you lose the signal very soon then I'd say the router is dying.
Good Luck
Mar 22, 2009 | D-Link Computers & Internet
Verizon DSL, keep losing signal, 2 different routers, same issue
try upgrading your verizonservase to the power pake one they might have a better router for you wich is the 29.95 on for high speed internet servas
Jan 04, 2009 | Actiontec GT704WG Wireless Router...
Wireless shuts off my laptop everytime I turn it off.
1.You probably have the internet connection shared through your computer..
2. you are either on a different channel or too far away.
Jan 17, 2008 | Acer Aspire 5050-3242 Notebook
Wi-fi
It's a common problem because the signal can get bounced off surfaces and not get to your notebook directly. The reason why you can get neighbours is because most phone sockets are near a window, hence the router is picked up quite easily by your Acer laptop as it has a Signal Up built into the antenna in your screen and because the signal is only going throgh mainly glass and air it tends to pick up more connections than some other laptops. it also makes a big difference if your router has more than one antenna and a long range capability in the settings.
Feb 11, 2007 | Acer Aspire 3502WLCi Notebook
Zyxel (91-004-361002) Wireless Router Logo
667 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
