Question about Electrolux Refrigerators
Not getting power on front panel - Electrolux Refrigerators
    Sergeant:
  • 212 Answers
What kind of refrigerator. if your talking bout the dispenser housing lights then check your plugs at the hinge above the freezer door. if this is not a side by side then tell me model
Posted on Jun 21, 2009
Hard drive light blinks as my speakers crackle!
Loose power cable inside?
Especially if the graphics card requires one..........
Loose HDD activity LED wire, on the Front Panel header?
[Front of computer is Front Panel. Area of contact pins on motherboard, that Main wires of Front Panel go to; is the Front Panel header ]
Power Supply NOT powerful enough..
Does not have enough power for computer system, AND graphics card
http://extreme.outervision.com/psucalculatorlite.jsp
Drumroll please...................And the desktop computer manufacturer name, and model number...........is?
[Model number is on the back of the computer, or up on the side]
Regards,
joecoolvette
May 04, 2013 | Computers & Internet
The front panel has a blue light and power , but i am not getting a picture or sound.
The blue light on the front panel merely indicates that power is getting to your TV. It is likely that there is a failure of the internal power supply
Mar 07, 2013 | JVC AV-48WP74 48" Rear Projection...
06 srx sunroof doesnt work
Sorry Bill but you don't the tool's or knowledge to take on this job . Control module's involved.
Which one does your vehicle have ?
Power Sunroof System Components -- CF5
The power sunroof system consists of the following components:
• Front glass control module and motor assembly
• Front sunshade control module and motor assembly
• Sunroof switch
• Front glass panel
• Front sunshade
• Power supply for the front glass control module and motor assembly logic: RAP relay
• Power supply for the power sunroof system: SUNROOF MOD fuse 40 A
Power Sunroof System Components -- C3B
• Sunroof switch
• Front glass panel
• Front sunshade
• Rear sunshade control module and motor assembly
• Rear sunshade switch
• Rear sunshade
• Rear fixed glass panel
Aug 30, 2017 | 2006 Cadillac SRX
My A/C panel will not turn on. Read A/C works just fine, but the entire front A/C panel gets no power. Suggestions?
Power to both front and rear A/C control panels goes through fuse No. 3 (7.5 amp) in the driver's under dash (left kick panel) fuse/relay box. But power to the main front panel goes through an additional fuse, No. 13 (7.5amp), in the passengers under dash (right kick panel) fuse/relay box. The other thing to check is the grounding point for the front panel (labeled G401 in wiring diagram.) It is located under the left side of the dash panel on a metal support with a through-bolt fastener. Many items ground at this point so look for multiple ring lugs under the bolt.
Mar 07, 2011 | 2004 Honda Odyssey
Get no power with intel d875pbz in rosewill tu155 case
You don't have the power switch connected where it belongs. There's one set of pins where all the front panel connections go. This information is from the manual for this board, available from Intel here.
Hope it helps. Thanks for using Fixya!
Feb 12, 2010 | Intel D875PBZ Motherboard
How can I fix the 'on' button on my computer. It
After a while of use the front cover of the PC can come loose causing the issue you are describing. What I would do is turn off the computer (actually unplug it to ensure you don't get shocked) and remove the front-panel of the computer (usually accomplished by prying it off starting at the bottom). If you think you will break the case doing this, remove the side-panel as shown here, then check to see if the front-panel is secured with screws. If screws are securing the front-panel, remove them. Afterward try prying the front-cover off again.
CAUTION: Touch the metal chassis of the case before placing your fingers near electronic components inside the computer! If you don't, even the slightest static-electricity discharge can break electronic components inside your computer.
Just so you know, I've removed front panels from computers multiple times. Never have I removed one without some form of cracking/popping noise being generated. Therefore don't get frightened if you hear one, it's quite normal (especially on Dells).
After you have removed the front-panel of the computer, inspect the power-button-depressor. We're checking to make sure it's not broken or that it slipped out of its housing. If the plastic power-button-depressor is broken, check to see if you can position it in a way that it will still be functional. If not I would remove (break off) the power-button-depressor, install the front-panel making sure that it seats firmly, then use some form of a small device (such as a toothpick, pencil (use the flat end), or some other small device) which will depress the actual power-button inside the front-panel.
However, if the power-button-depressor is not broken, simply install the front-cover making sure it reseats firmly. Afterward check to see if the power-button-depressor functions correctly.
If you're still encountering the same problem I would just break off the plastic power-button-depressor (requiring you to remove the front-panel again. Once again, don't forget to touch the metal chassis to prevent an inadvertent static-electricity discharge) and use a small device (as mentioned above, a toothpick, pencil, or other small device) which will easily depress the power-button inside the front-panel.
Hopefully reseating the front-panel will resolve your issue. Yet if it doesn't, you can still operate the power-button by use of a small device. No, you will not be shocked, nor will you come close to exposed electrical wiring (all wiring inside computers is insulated allowing you to touch it while the computer is running). Therefore the use of a small device to power on your computer is quite practical if your original power-button-depressor broke.
Let us know how things turn out.
Dec 29, 2009 | Dell Dimension 4600 PC Desktop
I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
Radio Speakers, Front Door Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 .
Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  3. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  4. Remove the front door trim panel.
Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
  1. Remove the four front door radio speaker screws.
May 20, 2009 | 1997 Mercury Villager
No power to front panel but have power to main unit.
You Have constant power (yellow wire) but your Acc wire or switched power wire (RED WIRE) does not have power. Check the connection of this wire. You most likely have a blown fuse in your vehicles fuse panel.
May 19, 2009 | Sony Xplod CD Player w/MP3 Playback...
Front panel wiring
Hi, Maybe we can wing it if you can send an image of the motherboard closeup on the F_PANEL connections and the wires from the front panel itself, or get the specific motherboard model during POST so we can try getting URL of manual. In some instances, the front panel wires are: Green wire, power on green light +, white wire is power on green light -; Red & Black, speaker; Red & white - HDD red activity light indicator where red is HDD + & white is HDD -; Orange & white - Reset Black & White - power on Post back so we can figure things out. Good luck and kind regards.
Aug 23, 2007 | Micro Electronics PowerSpec 8250 PC...
Refrigerators Logo
60 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
