Question about Crosley CR49-TW Tweed Traveler Turntable CD Player
Bought quasar turnable plays slow on 33
Turntable is to slow when playing album, way to slow,,,please help want to listen to my music thanks
SOURCE: Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Posted on Jan 08, 2009
scope eye
  • 4 Answers
SOURCE: Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Posted on Feb 10, 2009
  • 104 Answers
SOURCE: Getting the turnable to come on
some platters will not begin to spin until the tonearm is lifted up from the rest and over to where the record is, then it starts spinning.
alternately the belt may have come off.
http://www.archive.org/details/Turntable_Belt_Installation
will provide general info on how to put it back on.
Posted on Feb 11, 2009
Grubhead
  • 5508 Answers
SOURCE: I have a Crosley Keepsake turntable which plays 33
The only thing (I think) that would cause a 45 to play badly and the 33 not, is either the cartridge or stylus, most likely the stylus. It's either worn or damaged, so it fits badly in the larger grooves of 45's then the smaller ones of 33!
The signal coming from the cartridge is the same on 45 as it would be from 33.
Posted on May 25, 2010
AJIN G
  • 6694 Answers
SOURCE: turntable is slow, especially noticable on 33 1/3
hi,
your turn table is a belt driven one. The speed turns down when the belt become expanded. you should replace the belt of your turn table. Also put some lubricant in its center shaft ( not from the top lubricate it slightly after removing the plater).
I have here added some video related to the replacement of belt for turntables.
Not the exact for your one,for all the belt driven turntable the procedure is the same
ok
Posted on Jan 17, 2011
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
I just recently bought a new turntable, and when it plays my LPs, the LPs sound somewhat slower than the original. Does the slowness have to do with the belt of the turntable? Is there anyway I can fi
If the 45's play OK then your belt might not be fitted in the right place. If they are both slow, then either the belt is slack or the drive is faulty.
Dec 09, 2012 | Audio Players & Recorders
My Jensen JTA 450 is playing LPs too slow even though 33RPM is already set. The songs are slower than usual. Please help me.
The record that you are trying to play maybe a 45rpm recording. Some 45's were released in album size recordings.
Jun 20, 2012 | Audio Players & Recorders
Thomas Pacconi Model TPC-MSE-800 turntable runs slugglish. 78 runs fine but 45 or 33 runs slow. I removed belt cleaned it and platter. I put a drop on oil still same problem. Do I need a new belt? This is...
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Dec 16, 2010 | Seth Thomas Pacconi Turntable
I have a Crosley Keepsake turntable which plays 33 1/3 rpm records perfectly. However, when I try to play 45rpm records the sound is very distorted, especially the vocals which sound as though they are...
May 20, 2010 | Crosley 0187SST Turntable
Sony PS-LX250H is running slow from time to time notibly when playing slower songs like John Denver 33 albums.
Replace belt of turntable to fix speed issue. Part number is as follows:
421549201... BELT
Available in Sony Part Store for $10.31
Download user manual copy from Sony Support as belt replacement procedure is written in manual.
Thanks.
May 17, 2010 | Sony PS-LX250 Turntable
Feb 09, 2009 | Crosley Traveler Turntable
Crosley CR49-TW Tweed Traveler Turntable CD Player Logo
59 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
