Question about Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel GW612 Top Loading Washing
Fisher & Paykel GW612 Top Loading Washing Machine stops when spin cycle reached. Fault code 00X00X0X x= light on.No flashing lights
  • 2 more comments
  • Robert Eyer Sep 19, 2013
    From others post have already had the machine ready to work on and moving fan removed the obstruction - Thanks
  • Anonymous Mar 13, 2014
    fisher and paykel IW9-12 top loader code 9
  • Anonymous Mar 15, 2014
    Some of the lights on the control panel keep flashing. How do I reset it back to factory settings.
  • Anonymous Mar 23, 2014
    flood
  • 10 Answers
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • jimsaint May 15, 2011
    This was a life saver for me. And best of all it was SIMPLE! Thanks so much!!!
  • 86 Answers
This is a fault code 37,And indicates either a blocked or faulty pump,Suggest changing pump,Lean the machine forward (after bailing out water),And by lifting the little plastic lug on the pump mounting,And turn the pump anti-clockwiseto remove it.Hope this helps Cheers.
Posted on Jul 30, 2009
  • 205 Answers
Can't, off-hand, remember that specific fault code. Possibly a rotor position sensor in which case you will need a Tech. Call F/P
Posted on Jul 21, 2009
Fisher Paykel washer won't spin and drain. Any solution? Error looks like no E AP
possible answer for you see the link after reading Error/Fault code 00000101. (The value is 5.) It wasnt draining the water out at the rince cycle. I saw comments on fixya.com that others with the same problem found clothing between the outer bowel & the inner bowel or an item such as a necklace chain or hairclip jamming up the propeller..... (Two days later, see part 2....) I just fixed this F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.) Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!! Fisher Paykel GW612 Not rincing spinning part 1
Mar 15, 2018 | Fisher Washing Machines
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
It drains an fills up with water it wont spin an go through first cycle
Does It just shake bowl left & right, it will soon give you fault code 56.
Well its a board problem you will need to get technician to fix this board, three resistors(R129,R130,R131) need to be changed for a 1MegOhm resistor.
Sep 03, 2012 | Fisher and Paykel Washing Machines
The washing machine fills with water but then appears like it struggles to spin and then it stops attempting to spin, then starts to beep and flash lights. the lights that flash are the middle green...
Hi just read your posting.Now the lights that are flashing are an ERROR CODE .On the row of 8 lights that these lights are flashing which ones are flashing,starting from the left to right of the row is it the 2nd and 3rd and 8th or the 1st and 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Jul 30, 2010 | Fisher and Paykel Washing Machines
Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Mar 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,642 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
