Question about Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player
Avp7000 for a while when driving we 'd lose the picture when taking right turns then it would reappear when taking a left turn. Now the is simply no picture. Is this a problem with the heads?
  • 979 Answers
Sound is OK? Suspect a problem with one of the following; Heads, head amplifier, drum control servo IC, or video processing, in that order, assuming that you have audio....accordianman
Posted on Nov 03, 2007
As I drive especially if I accelerate hard front wheels seem to sway
It can be a few things wrong here so the best thing for you and the safest for me to say is take it for a m.o.t even if you still have a long m.o.t. left not much money to pay to get this right
Jul 09, 2017 | 2003 Pontiac Bonneville
My 2000 cavalier loses power when the steering wheel is turned right
You have a problem in the engine wiring harness where it goes through the firewall, check for chafed and damaged wires.
Feb 21, 2012 | Cars & Trucks
Hi I have a Toyota Corolla 2001 160i. when I drive over 100kms my steering becomes very loose and there is not much tension anymore. Also when I turn left or right I hear a noise, like something under the...
As you said, steering feels lose while driving and makes noise on turn, please don't drive as it condition. It seems cars front low arm lose or got damage, get it check on urgent basis. It is danger.
Yogesh Mule
Sep 15, 2011 | Toyota Corolla Cars & Trucks
I have a hard clicking sound coming from the front left tire of my 2003 durango. The clicking occurs when turning in reverse and accelerating going straight. When I lifted the front left wheel I could...
could have been lose lugs
or ABS sencer
or something cought in tire area back of rim or even the wheel well splash gard lose
stock tires will not have this issue but over sized ones might
just some areas to check on
Nov 28, 2010 | 2003 Dodge Durango
The TV Sony KDF-60WF655 turn on and the screen is all blue, can see the picture but not clear and thge picture keep scrolling from right to left
The reason your television has a blue screen and scrolls from right to left is simply because there is a problem with a board in the television.
The board is known as the t-con board and as soon as you get it replaced, your television will be in good condition again.
You can have a repairman replace it for you, or you can replace it yourself.
But to be on a more safer side, I will strongly advice you allow a repairman fix the problem for you.
Take care
Jul 15, 2010 | Televison & Video
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
had a glitch where the software on the phone took pictures and video clips in reverse but contacted Samsung and got clear instructions how to sent it back which resulted in updating of software.
Jan 19, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Memory card problem
The only solution left is to get a card reader and insert the card in the card reader.
when the card is detected it will show a removeable drive in My Computer. Right click on the removeable drive and click on click on the the tab which says under error checking click on Check click both the option that is Automatically fix the system errors and Scan for and attempt recovery of bad sectors.
After the scan is complete the card will work fine.
May 30, 2008 | Kodak EasyShare C633 Digital Camera
Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
