Question about Hotpoint HSS25GFP Side by Side Refrigerator
Chemical Smell and water drippping from top freezer into Frig
I have an old Hotpoint. (atleast ten. I came home one day to find water pooled in the bottom of the fridg. I was dripping down from the freezer compartment. I placed a bowl under the vent that was leaking water and it stopped dripping after a few days.
Also, there is a strong chemical solvant like smell in the freezer that almost burns my eyes. Lastly, I notice a random buzzing inside the freezer a few times per minute. It is random lasts for less than a second and sounds like an electrical problem to me.
  • 3,230 Answers
First of all you please follow the below links -
http://www.repairclinic.com/0088_4_1.asp#Level1_4
http://www.repairclinic.com/0088_4_1.asp#Level1_5
Post further comment after reading the whole info.
Thanks
Posted on Jun 21, 2009
I have a Dometic RV frig and a week ago it started to smell of spoiled dairy. I cleaned every surface and checked all the refrigerated products, but the smell continues and is getting worse. Please
My rv refrigerator doesnt have a drain but I do know how to get stink out of a refrigerator providing everything has been wiped up. My freezer at home was accidentally unplugged for weeks with two bears and half a deer in it. Life altering stink ensued. I tried every kind of cleaner and procedure including running it with charcoal briquets in it. Nothing worked and I was getting ready to throw it out until I was told to wipe it down with vanilla extract. It worked immediately and has been fine ever since. Cheap and easy.
Jun 10, 2017 | RVs
I have hot point refrigerator that water is collecting in the fridge part i have cleaned drain up top it is still dripping what now
Sounds like you missed the clean out of the control in the refer section, that has a cup in the behind the cold control within the plastic housing. This can also get clogged and cause this issue. You are almost home free in this issue you have. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 04, 2014 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
I have Hotpoint model CTX18BABKRWW Serial#ZT515963. Water is collecting in frige under two drawers. I cannot find a drain or a drain tray. Sounds like a low hum noise. Frig is cold and freezer is...
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
Aug 15, 2011 | Hotpoint Refrigerators
Can't get the fishy smell out of fridge....used baster and put water with baking soda down drain under bottom freezer bin... took back off...cleaned compressor Hotpoint HSS25GFPA
I was watching tv the other day and they said if you want to get rid of awlful smelly smells use newspaper. Put newspaper in the frig and close the door. Let set for like two days and repeat. The newspaper will absorb the smell somehow because of the chemicals it has. It works great with pickle jars. no kidding.
Mar 23, 2010 | Hotpoint HSS25GFP Side by Side...
Chemical odor
This can be a result of chemical reaction in internal parts. If you notice it is faint the keep orange peels to get off the smell. It could be the freon. It is kind of like your a.c. in your car. It is the gas that makes it cold. You might have a leak. Thank you Sir, Have a nice day.
Sep 17, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Sep 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Pooling Water
Hi!!!Your drain line is frozen and plugged.Try to remove the cover of the evaporator and you should see a small hole on the base of the evaporator thats yout drain line hole. Blow it away and your problem is gone..Good luckk..Plugged drain line..
Dec 23, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
