Question about Kenmore Elite 45986 Front Load Washer
Error Message F11
The machine was just installed by Sears, the men left I put in my first load of laundry and I get this error code...
  • 6,784 Answers
This represent a Serial communication error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
Posted on Jun 22, 2009
  • Michael Masters
    Michael Masters Jun 22, 2009
    In most cases here, the wiring harness will be defective or, not connected properly during the manufacturing process.
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    I have a 300 Series Bosch front load washing machine witn an E:27 error message. I can't get it to reset. What is wrong?
    Do you know what the E:27 error code means? Different machines have different codes. I am not a bosch expert, but if you provide the complete model # to your machine chances are good that i can find the meaning of that error code and maybe a whole lot more.
    Jan 06, 2013 | Bosch Washing Machines
    I have an F11 code
    Washer will suddenly stop with 1 minute left on cycle and shows the F11 error code...at times it may show the FdL code. The washer will then not finish no matter what I do. If I unplug the unit from the outlet that does not guarantee that when I plug it back in it will start up. Fifty percent of the time it still shows the F11 error. It can take hours to finally get the washer to cancel out so I can take the laundry out that has not been spun out.
    The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
    • A loose or failed wire harness connection between the central control board and the motor control board.
    • A bad wire harness connection between the motor control board and the drive motor.
    • A failed drive motor.
    • A defective motor control board.
    • A failure in the central control board.
    The diagnosis of this failure usually requires a technician. If you are able to unplug the washer and safely access the central control board and motor control board, you can check for a loose wire harness connection.
    Jan 24, 2011 | Kenmore Elite 45986 Front Load Washer
    Error code "UE" clothes have
    UE = Unbalance Error
    Laundry load is unbalanced, manually loosen any tangled laundry.
    If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
    Thanks for using FixYa !!
    Dec 12, 2010 | Washing Machines
    We get an e3 error message and we have no idea what that means. The machine will start but then at some point it simply stops. we have been able to use the rinse and spin cycles to get the water out of the...
    It's an over load error. Don't put alot of laundry in the drum.
    Copy and Paste from the service manual
    - Motor overloaded due to too much laundry (Nonsensing)
    - The motor hall sensor terminal is not connected.
    - PBA fault
    - The motor driving error from the PBA is weak.
    : Unstable relay operation, etc.
    This error
    occurs when an
    interference is
    generated due
    to too much
    laundry, etc.
    Dec 28, 2009 | Samsung WF337AA Front Load Washer
    Error Code F11
    TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
    Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    What does a F11 error mean on a Kenmore elite HE3t?
    the first thing u must do is ID who makes this machine for sears, sears doesn't manufacture anything, here is the page that shows you how to do that, then with that info i can look up the code difintion. go to link
    http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears /
    Oct 23, 2009 | Kenmore Elite 45986 Front Load Washer
    Washer
    Product Laundry Washer
    Symptom Error Codes
    Sub Symptom LE error code
    Question Locked motor error code.
    Answer
    LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
    please do not forget to rate and comment about your experience with fixya today.
    Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
    Lg wm2277hs
    Symptom Error Codes
    Answer
    Kenmore Elite 45986 Front Load Washer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
