Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a John Deere 400 tractor (1978) that won't start. The fuel line is dry. I was able to draw fuel to it with suction to prime it and have also used started fluid but am wondering whether there is something to try before replacing the fuel pump.
    Genius:
  • 1,847 Answers
You will need to also determine if the problem is a lack of spark . Remove the spark plug, reconnect the wire and lay it against the engine head. Pull the engine over and watch for good hot spark at the plug's electrode.
If good, then try to start it while squirting fuel or starting fluid into the carb intake. If it starts and you can keep it running by adding fuel, then the carb most likely has dirt, debris or gummed fuel inside.
You will need to remove the carb, disassemble it, clean all the small internal openings and blow it out with compressed air. Probe each and every hole with a small wire. A carb rebuild kit wouldn't hurt either. if all is fine then just replace the fuel pump.
Thanks
Kindly rate the answer
Kevin
Posted on Jun 21, 2009
John Deere 5520 tractor won't start. I've replaced the fuel pump, fuel lines, bleed the air out. It turns over but won't start.
check the fuel pump timing
bleed the air out of the pump
bleed the air out of the injector lines
Oct 06, 2015 | John Deere Garden
Just wondering what the year of my John Deere 400 is serial number C400J123028M. It has the 20 HP Kohler motor in it.
JD 400 Garden tractors were made from 1975 - 1983.
Serial Numbers
1975: 30001
1976: 55001
1977: 70001
1978: 80001
1979: 95001
1980: 120001
1981: 155001
1982: 190001
Go to this site and you may be able to track it down.
John Deere 400 attachments
http://www.tractordata.com/lawn-tractors/000/0/4/41-john-deere-400-attachments.html
Be sure to read this discussion on serial numbers.
Tractor serial numbers
"Find the REAL serial number
There are usually a lot of different numbers on a tractor. The engine, front axle, and cab may all have their own serial numbers. Various components may have parts or casting numbers. Make sure you have actually found the tractor serial number, and not one of these other numbers."
Mar 18, 2015 | John Deere Garden
2320 johne deere disiel tractor cranks over but won't start
check fuel filter first and that fuel pump works by openig at fuel pump and pushing fuel out just short of injection pump-- if no fuel pushes out prime fuel system by pushing air into fuel tank or using a in line hand fuel pump--- fill tank on tractor so that fuel is above injector pump also helps probably a prime problem
Mar 14, 2014 | John Deere 420,1020,2010,2020,2510,2520...
How to prime a john deere 6415 after replacing fuel filters
disconnect the fuel lines after the filter and crank it. then hook the lines back up and crank it over. if its a diesel use some starting fluid and spray it into the intake to prime it.
Jul 12, 2011 | John Deere Garden
Skid steerer won 't start
You need to remove the fuel filters and fill them with fuel, and them if you engine is equipped with a primer,,,,prime the fuel system.
Simply filling the fuel after a run out will never start it. The system has air in it that needs to be primed out.
Aug 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My john deere 245 lawn tractor will not start only backfires out the muffler.
There are 2 likely problems.
First spray a prime in the carb and see if the motor runs on a prime. If it does then you need to remove your carb and clean- there is likely water in your fuel.
Second- check for a sheared flywheel key.
Dec 28, 2009 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
124 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
