Question about RCA D61W20 61" Rear Projection Television
Power supply sparking on hdtv model D52W19B
I plugged in the tv to find out if I could see the problem. when I powered up the tv a square box on the power supply board was sparking. it has 200vdc on it on the left hand behind what looks like heat radiator. about 3/4" by 1" and 1/4" thick. It burned one side of the sauder and got loose. having a hard time finding a replacement board. All it has on it is psb 850
    Problem Solver:
  • 5 Answers
For people who have these RCA projection TV's, please have the deflection boards checked. Look on the underside of the board where the gray box thing is and make sure there is plenty of solder there. I looked at mine and it looked like the solder was flaking off. Luckily a hole wasn't burned in but it was starting to turn black due to heat from the loose connection. I put new solder on mine and my TV no longer sparks.
Posted on Jan 31, 2012
  • RCA Master
  • 8,617 Answers
You cant get the replacement board but you can get the part that sparked. Heres a link to that Gray box Capacitor.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-box-capacitor-0087uf-2000vdc/cName/rca-parts
Posted on Jun 21, 2009
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don't get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
My rca tv d52w19b dont turn on
There may have been a power supply failure.
Apr 15, 2014 | RCA D52W23 52" HDTV CRT TV
Samsung model a3079dh hdtv 5 blinking lites when pushing power button
Remove the back and check for bulged electrolytic caps on the power supply, or replace power supplu. You can go to www.partstore, for anew supply.
Oct 16, 2010 | Panasonic TH-42PHD7UY 42 in. HDTV-Ready...
I have an emerson model LD195EM8 that will not power on
Ur tv front screen panel power LED light indicator flashes?Check ur power source like the plug in outlet yet?Yes,Than.The power supply board it dead.That the board where the a/c power cord plug into it.Take the tv aparts,replaced the power supply board.Ur tv will have power again and work.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
The power safety fuse was blown. I replaced it but everytime I plug the TV, it blows the fuse. It is a Sony projection HDTV
When fuse blows again and again that means power supply is bad and needs to be replaced.
Let me know exact model of your Sony TV to provide you power supply board part number info.
Nov 03, 2009 | Sony KP-51WS510 51" Rear Projection...
My flatscreem tv only stays on for approx 10 seconds and cuts off. Picture clear when tv is on. Cable box working properly. I have A LCD HDTV Model 332-BG11
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Oct 21, 2009 | Olevia LT37HVS 37 in. LCD HDTV
RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Jan 16, 2009 | RCA D52W23 52" HDTV CRT TV
Computer stopped working - I see a spark when I plug onto motherboard
the spark you see is a shorted power socket on the MOBO, the spark is shutting down the power supply for protection. You need a new board.
May 19, 2008 | Intel D945GTP Motherboard
TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
P/N: 6693006610
Model: HOAU242001(A)
Scheda Inverter PWB-0656-03
Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
RCA D61W20 61" Rear Projection Television Logo
309 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
