Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Removing seat cover maxi cosi priorifix
I need to remove the seat cover to wash but i jus canny do it the seat belts are in the way please help
Peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat. Extend the set belts to their maximum length and recline the seat as far as possible. Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions). On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the **** belt at the bottom. Unhook the looks from the shoulder straps from the metal clasp. Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to was. A great design hey ! Good Luck.
Posted on Dec 12, 2009
  • 21 Answers
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Posted on Jun 23, 2009
Maxi cosi car seat opal
Hi Laura,
To change the beltpads on the Maxi-Cosi Opal harness the carseat would need to come in for our engineers to remove the shoulder harness section and replace.
Apr 09, 2013 | Maxi-Cosi Opal Car Seat in Total Black
Can you remove maxi cosi car seat covers
All Maxi Cosi carseats are designed with easily removable covers for washing. Instructions on how to remove them can be found in your User Manual for the carseat. If you need a replacement User Manual please visit www.maxi-cosi.com and select the country you're in, then choose the model carseat you have and an option will appear for viewing or downloading a replacement User Manual.
Apr 07, 2012 | Maxi-Cosi Baby Gear
Where can I get replacement belt hooks from? Both of mine have come off my maxi cosi priorifix car seat. Many thanks. Marie
Good Afternoon
The belt hooks for the PrioriFix can be obtained via your local retailer or direct with the customer service department.
To find the customer service department for the country you're in go to www.maxi-cosi.com and select the country you're in, then go to "Contact Us" and you can get in touch with the customer service department where you are for further assistance.
Jul 20, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Just bought a maxi cosi priorifix car seat and the handle for the recline is very loose and kind of flappy, however it does work (i.e. the seat moves and locks into the 4 positions) is this how it should...
Good Evening
"Loose and kind of flappy" is not how the recline handle on a PrioriFix carseat should be described - Please contact your retailer with your proof of purchase and ask them to compare it to others in store to check whether yours is different. If it is, they will be able to assist from there.
May 19, 2011 | Maxi-Cosi Priori
Have a maxi cosy car seat and can i remove seat cover to wash and how?
www.buggypitstop.co.uk are a professnal cleaning company and they clean car seats including maxi cosi, they should be able to help you
Dec 10, 2009 | Maxi-Cosi Cabrio Red Flame Reflection...
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Oct 20, 2009 | Maxi-Cosi Priori
How do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
May 15, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi-cosi priorifix - fitting with seat belt
Sure!
Please download the manual via this link.
The instructions are on page 10, paragraph D
http://www.maxi-cosi.nl/media/producthandleidingen/maxicosi/PrioriFix.pdf
With kind regards,
www.babycare.nl
Erwin de Raad
Apr 18, 2009 | Maxi-Cosi Priori
Removing maxi-cosi priori cover
under the strap that is just below the grey round plastic length adjuster there is a stiched loop. Pinch the stiched loop and you will see that it can be removed.
Sep 06, 2007 | Maxi-Cosi Priori
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
2,507 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
