Question about Epson Office Equipment & Supplies
I have to uninstall my toner cartridges in my epson c1100, to install in my new printer. i cannot get my old printer to uninstall the toner
    Novelist:
  • 152 Answers
If you are installing a new printer, you should not need to remove the toner cartridge from the old one. If however you are trying to replace the toner cartridge, when you open the device, there should be a off color button you press to release the cartridge from it's position so you can remove it.
Posted on Jun 21, 2009
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
I keep getting a message on the printer saying install C TnrCart Ive repeated the process twice and installed a new toner but it keeps saying it?
Epson C1100 toner detection is based on freq. your chip on the toner might be old or faulty.
The toner does not have contact point.. at the right side of the printer, there is a receiver, and at the side of the toner, there is a round chip..
Apr 07, 2010 | Epson Aculaser C1100 Printer
Epson C1100 K toner low, right hand side can't print
Well if the margins are not the issue, then I would change it.
But before that, try taking a cotton swab, and cleaning the "k toner", the bottom part where the ink comes out. This way before investing more money into your printer, this 'k toner' might just needed a bit of cleaning.
Good luck
Sep 10, 2009 | Epson Aculaser C1100 Printer
Override Toner Out on Epson C1100
This may or may not work but you can try taking the toner cartridge out and carefully shaking it, (don't spill it on yourself) then re-install it and see if you've shaken enough toner loose to fool the printer.If so it may make a print for you if this doesn't work you have no option but to replace the toner cartridge.
Aug 31, 2009 | Epson Aculaser C1100 Printer
Remove all toner cartridges
It took me some time but I found the sollution:
Remove the powercord from the printer.
Open the front door and remove the first toner.
Close the front door and open the top door, remove the photo conductor.
When the front door is closed, you can turn the toner trommel and move it so that the second toner gets in the remove position.
Open the front door and remove the toner.
Close the front door and turn the trommel.
Repeat those steps until all are removed.
Jul 30, 2009 | Epson Aculaser C1100 Printer
Installing Epson TO88120 on Epson NX1000
On the LCD display choose the 'Reset Menu'Then within that menu keep going through the (many) options 'till you get to 'Change Toner K' (K for black, C for Cyan, M for magenta,Y for yellow).
Once you select the appropriate Toner it will rotate to offer the toner for replacing.
Open up the cover at the front, reach inside and change the position of the coloured part of the toner cartridge on the R/H side to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out slightly ahead of the other side.
Put the new toner cartridge in and turn the coloured part to the locked symbol and close up.
Please take a moment to rate this solution, thanks.
Apr 08, 2009 | Epson Aculaser C1100 Printer
How to install toner chip on epson c1100
The toner chip is situated on the end of the toner cartidge - it's a circle, about 1.5cm in diameter.
They may have given you a new housing, in case you damage the one currently on your toner, when you try to remove it.
Nov 15, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Oct 28, 2008 | Epson Aculaser C1100 Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Sep 04, 2007 | Epson Aculaser C1100 Printer
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
