Question about Homelite Mighty Lite Lawn Trimmer
Homelite 26tv wont start
Cleaned carb and spark plug put fresh gas
Thanks
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 24, 2009
  • Jim Parker
    Jim Parker Jun 27, 2009
    Did this solution solve the problem?
    Jim
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
I have a old homelite that won't start new plug fresh gas no spark
Most of the time on older engines, the carb needs to be rebuilt or replaced. Dont panic rebuilding is cheap an easy. The ports get clogged up sitting an varnish up. Try to clean out all orifices with small pieces of wire from steel or brass brush. Use carb cleaner to clean replace all gaskets an parts with kit. Dont forget to check fuel hose in tank they go bad often an should be replaced when carb work is done. Fresh gas an it should work
Mar 11, 2014 | Homelite Garden
I have a weed eater trimmer that wont start. ben sitting for a couple years and i replaced the fuel lines andcleaned the carb. still nothing, what do i do?
Try cleaning the spark plug, make sure it sparks. Put some fresh gasoline in the tank, check start stop switch.
A easy way to check whether the problem is related to carb or not is:
remove the spark plug put some fresh gasoline in the cylinder, put the spark plug back
pull the starter a few times if it starts for a few seconds it means is related to carb.
Be carefully when handling gasoline.
Aug 05, 2011 | Troy Bilt Tb70ss Gas Trimmer
I have a new batiere in my 1991 vino 50cc tow stroke, And the starter wont work and it wont kick start even with starter fliod. Anything that I can check or replace?
Check fuses. Get a new spark plug then check for spark by hooking up the plug wire then hold the metal side of the plug against the cylinder. Have a friend kick the engine over while you look for spark. Remove the carb, then remove the float bowl from the bottom of the carb. Use spray carb cleaner to clean the carb. How old is the gas? Flush the tank and fill with fresh fuel if old gas is present. Please rate my answer. Thanks.
Apr 06, 2011 | Yamaha G5 Motorcycles
I have never been able to start my homelite mighty lkite 26cs weed eater.......
check that fule is getting into the engine and you have a good clean spark plug with a good spark on it and the air filter is clean
try tipping a cap full of fult (2 stroke mix) into the carb throte right into the engine then try to start it up,,if it spluters into life and stops the carb jets are blocked up or no fule is getting to the card
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
My 16" Homelite chainesaw will not start. I have fresh fuel, and good spark.
Remove the spark plug and try spraying starter fluid or carb cleaner into the cylinder. If it starts and then dies you probably have a carb problem and will probably have to clean it. You can try spraying carb cleaner in it and see if it helps. If it has been sitting, if could be due to the fuel. Gas has ethanol that attracts water and causes corrosion and clogging problems in the carb. You can use a fuel stabilizer to treat your gas and avoid this problem. Hope this helps.
Feb 28, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Trimmer fires up but then stops , I pump the bulb and it starts again but then stops
Ok... 1. Make sure your Air Cleaner is clean 2. Empty out any old gas in the system from last season. from the tank, carb, and fuel lines. 3. Make sure that the gas filter in the tank is clean and free from blockage. 4. Clean out the carb jets with spray carb cleaner. 5.Pull spark plug and clean wih carb spray as well. 6.. Reassemble n fill with fresh gas/ or gas/oil mix if 2 cycle. let me know how it goes... k
Jun 10, 2009 | Homelite Garden
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
197 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
