Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Poor reception when i talk on the radio i can only talk to someone for about a 1/4 mile and i loose contact i do not hear a lot of sound from the radio unless the person is close bye, i have the rf gain and squelch turned up all the way, the ant. is a wilson 2000 and the wire seems ok the whole setup is about 8 yrs old, i hear a noise when the radio is on it almost sounds like electrical is turning on and off like when you step on the brake and the lights come on it clicks in the radio also the swr meter is not working the meter doen't work at all, the lights in the radio do not work but i read the responce for you with one of your other customers on that issue. what do you think is the problem is it just age???? the setup did sit in my garge for about 3yrs.
  • 2 more comments
  • christopher jolly Nov 13, 2007
    installed a new k-40 ant. and new wire system seems to work 100% better.
  • tazman13 Dec 15, 2007
    when the squelch is right off no noise comes out of the speakers and the cb itself has very limited range .. about 1/4 of a mile
  • perrys May 04, 2008
    Cobra 29 wx/nw..Brand new,just installed in a Columbia Freightliner.Only 1/4 mile or so reception.Antenna's are stock and I go way over 3 when I try to calibrate this. Also no noise on the speaker when the squelch is turned.
    This is frustrating.I just took my old Cobra 29 out of my Classic which I was getting 5/7 mile range and the same problem in this tractor. No range at all.
    Any help would be appreciated.
    Thanks
  • Steve Tompkins
    Steve Tompkins Feb 25, 2013
    Sometimes finals go bad sitting around..Get a watt meter. Test its power it should put out atleast around 10 watts Rf factory and SWR should be at 1.5 or less to 1.1 on a meter. It should get atleast 5 to 10 miles range if antenna is up atleast 15 feet in the air outdoors or on a rooftop of a car. Dead center the roof is best on a vehicle the wave spread out at 360 ' radius equal in center of metal.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Better antenna located higher up.Make sure its 50 feet from the house or other objects & power lines. I just used an Antron A99 17'4 ft antenna at $59 with 50 ft RG213u or RG59 coax on a 30 feet tv pole and got ranges of 20 to 50 miles easy using a small car radio Uniden 76xl in my bedroom on a Radio Shack 12 volt DC 3 amp power supply..In a car a magnet mount in center of roof will do a good job. www.copperelectronics.com has antennas,coax,microphones,radios,power,mics. etc.
Posted on Mar 07, 2013
    Novelist:
    Champion:
  • 211 Answers
Sounds as though You have a bad antenna system ( may be bad coax ). Unless there is infact something wrong with the radio ( this is unlikey) you need to have the SWR's ( Standing Wave Ratio ) checked and trouble shoot the antenna problem. Although the ST seems to be ( In my opion ) the worst recieve radio Cobra could develope, they normally work to a good standard. As for the meter not working, this may also be lack of a good signal from the ant problem. If infact the antenna and coax is good, then take a close look at the output ( final ) transistor. If it's shorted, it doesn't receive well nor does it transmit well.
Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
BPR40 Receiving a static reception when someone is talking
Several things need to be checked. Fully charged battery. Antenna, make certain it s tight and unbroken. Wiggle the antenna while receiving, if reception improves, it is the antenna or the antenna jack. Then wiggle the on/off vol switch, same thing, if reception improves, it is broken or needs to be resoldered. Then I check the speaker. Speakers gather metal particles, as they get more and more, the speaker distorts and it sounds like static. Use a powerful magnet, run it over the speaker grill and see if anything comes out. I put plastic wrap on the magnet for easy cleaning. It could still be a bad speaker. Last, I check programming. All of this is done at our shop regularly and I suspect most radio shops follow the same procedures, maybe in a different order. Post if this helps or not.
May 17, 2016 | Motorola MagOne BPR40 UHF 8-channel...
What is the range for motorola T7100
line of site. Low power radio = not much range. Describe your conditions/applications and I can give you a better answer. Such as, will it talk 5 miles is not as good as I am in a building and need to talk to the parking lot.
Jun 05, 2015 | Motorola Radio Communications
Poor reception
There are many causes for poor reception on a cb radio one cause may be poor or poorly assembled antenna, a good antenna should be of highest gain and put up as high as possible ,An omnidirectional antenna or Ground plane will hear moderately well
in all directions but a directional antenna or Yagi will hear great only in the direction it is turned you will certainly have to decide what you or your homeowners association will allow.
Also and finally The sun is a major factor in communications Propagation sometimes no mater what your setup the reception is terrible.
Feb 24, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Is there a way to get more range from a cobra 29 ltd? My buddy and I purchased this CB and are having difficulty getting a clear transmission at less than 1 mile apart on the freeway. Need help pleas
Is your buddy able to hear other radio traffic (squelch and RF gain adjusted for maximum reception)?
Is your microphone gain turned all the way up?
Did you follow the instructions for tuning the antenna with the built-in SWR meter? The built-in meter should be 'good enough' to get by with.
Is the antenna a decent brand/length? (Longer is better, the cellphone look-alikes are junk).
Was the radio bought new or used? If used, it might have a blown output.
Mar 07, 2012 | Cobra 29 LTD CB Radio
Cant hear other radios if over 1/4 mile away
Are you using the noise blanker? Are you also finding noise on regular AM radio in vehicle? How good is the connection on the coax?
How good is the antenna ground to chassis? How good is the antenna?
If you address the various sources of general RF hash that would also aflict the AM reception in your vehicle, that would be the first thing to address. It would probably be a good idea to use some contact cleaner or LPS1 and spray down the switches and controls. I know on one of my own that the dirty contacts are enough to kill off reception.
If these things do not improve it, and you do not mind going into the radio- in the reciever stages are a number of 1N60 diodes, and they have a nasty habit of becoming leaky and noisy. Replacing them should help quite a lot if nothing up to this point has.
Jan 27, 2012 | Cobra 29 LTD CB Radio
Poor reception through wooded areas , and over hills. overall poor performance, will not work sometimes 1hundred yards in woods. advertise 26 miles! any help appreciated
Poor reception will be experienced in wooded areas and this is normal as the trees absorb RF energy. Range is dependant on conditions and terrain. Better range over water and open Country side, poor range in the middle of a built-up area. Low band better in hilly areas and UHF better in buildings. I have yet to find a pair of walkie talkies that will talk for 26 miles without a repeater.
Dec 14, 2009 | Midland Two Way Radio
AM reception
Since there is no AM antenna input on this radio, you will have to get an AM proximity antenna. One that does not need to connect to the radio. At Bose they recommend the Terk AM Advantage proximity antenna. I think you can get it on Audiovox.com.
Jun 17, 2009 | Bose Wave Radio
My radio on my82 honda goldwing dont have sound
(Better1969) is correct. I just bought a 1983 Aspencade and there was no sound to my speakers. The gentleman I bought the bike from supplied new speakers but I quickly ruled that out. There are 3 fuse links behind the left turn signal in the fairing. 1 was a 1 amp, 1 was a 2 amp and the blown fuse was a 5 amp. I didn't have a 5 amp so I put a 2 amp in its place. So far the sound is still working but my FM radio reception is very poor.
May 14, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
325 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
