Question about Canon PowerShot SD600 Digital Camera
Cannot take photos
Screen shows "card locked"
  • Canon Master
  • 4,738 Answers
First I know you may have already checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position (a single grain of sand can jam it there). With a plastic toothpick, or other skinny NON-METALLIC item, tap and gently push against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, to clear out any gunk that may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
    Problem Solver:
  • 16 Answers
Trust me it happened to me and i had to get another (SD) card or whatever
Posted on Jun 21, 2009
2 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Screen shows 'card locked' ,Unable to take photos
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Posted on Oct 30, 2009
Samsung es60 card locked solution
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 22, 2014 | Samsung ES60 Digital Camera
Network unlock for samsung gt-e2120
Hi, You can get the unlock code for a Samsung E2120 from www.simpleunlocking.com/samsung-e2120/rs16wp9/ at low cost.
UNLOCKING STEPS FOR SAMSUNG E2120
Method 1:
1 - Switch ON your Samsung E2120 with a NOT ACCEPTED SIM Card.
2 - Samsung E2120 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung E2120 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung E2120.
3 - Compose : #0111*CODE#.
Nov 02, 2012 | Samsung Cell Phones
After Taking Photograph shows good in back screen but after transfering to Pc it shows very Dark why it so ?
use high quality speed card. secondly every camera company shows you bright picture because they want to cell their product with bright screen. so if you are a photographer then you ahve to use screen brightness and darkness in camera keep it on -2 setting
May 21, 2017 | Nikon D70 Body Only Digital Camera
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 24, 2012 | Canon Cameras
Samsung ES10 8.1MP, card locked can't shot a picture
camera shows card locked when you insert memory card and can not take photos but without memory card it takes photos.even when you change memory cards it does the same.it says card locked.
Dec 25, 2010 | Cameras
When i captured the photo, Showing Card Protection on Screen. How can i Disable. Plz reply asap Adv Thanks Giri 9441069185
Check the tiny switch on the memory card to see if it is locked, unlock it. Otherwise, you need to goto menu in playback mode to unprotect the pictures.
Dec 20, 2010 | Polaroid i835 Digital Camera
Screen shows 'card locked' ,Unable to take photos Memory card checked. It is not 'locked'. Exchanged yto new card but still ;card locked'.
Oct 20, 2009 | Canon PowerShot A550 Digital Camera
Casio exilim 8.1 card is locked
Hi!
Can you check if there is a small push button on the memory card itself? It could that it is currently on write-protect mode.
Aug 29, 2009 | Casio Exilim EX-S600 Digital Camera
LCD shows MEMORY LOCKED even thought card is NOT LOCKED!
Go thru all the pages on the camera setup in the camera. You may find a memory lock conrol. That is there to keep you from accidently erasing photos.
May 03, 2009 | Canon Cameras
Canon PowerShot SD600 Digital Camera Logo
176 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
