Question about Dryers
Water in dryer
How do i stop water from condensating in my dryer.
  • beaudans Jun 21, 2009
    dryer has great air flow.
    water collects in it while the dryer is off.
    i thought this may be a common problem and maytag or some after market product would have an easy fix for it but i guess i was wrong.
  • 439 Answers
Clean out the lint trap and the vacuum the slot it goes into. Also clean out the vent hose and vacuum out all of the lint inside the dryer where the hose attaches. This is normally caused by lack of air flow.
Posted on Jun 21, 2009
  • Matthew Boulden Jun 21, 2009
    Unless you have water leaking into the dryer it is caused by a high humidity level in the room the dryer is located in. If the dryer is located in the bathroom it is more than likely caused by hot showers, if not I would use a dehumidifier in the room it is located in. This should work for you.
    I understand your frustration, but water in the dryer is not a common problem. It is just caused by humidity in the room where the dryer is. If you do not have a vent hose attached this will cause the same issue.
Dryer Electrolux EDP2074GDW stopped functioning. The question mark is on. Pressing the buttons don't operate the machine. How do I reactivate the dryer?
Condenser dryer? check the tank water level and drain - condenser doors are closing correctly and fluff filter is clear. Question mark doesn't mean fault always - you need to check something. Error codes usually begin with F something.
Oct 15, 2017 | Electrolux Washing Machines
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Condensed dryer keeps tripping out my electric when I turn it on
Disconnect from mains. Remove rear panel and water will probably come out. This water is being flung by the fan onto the heater hence tripping the electric.
cause of water being here is a blockage in the condenser stopping flow into water chamber or possibly but unlikely, failure of the pump
Oct 11, 2014 | Hotpoint Aquarius WD640 Front Load...
Condenser dryer
PULL OUT THE PLUG
on the bottom right on the back is the water pump
it needs cleaning or replacing
not lifting the water to the water draw
Dec 12, 2013 | Creda IWD12 Front Load Washer / Dryer
Dryer will not stop beeping
I wonder if maybe you need to dump the water tray (if this is a condenser dryer). Not all dryers are the same but a continual beeping must be a notification of some sort, like maybe a over heat problem due to filter being clogged vent pipe kinked (if applicable) A condenser dryer does not have venting. The water has to go somewhere so it is captured in a basin and has to be removed on some machines while on others it gets pumped out. Pump failure res overflow who knows, you should post brand and model for a better answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2013 | Dryers
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
My condenser tray is not filling up with water but the dryer is still working. where is ther water going and why do my clothes smell ?
I have the same problem, my water is gathering behind the condenser unit but it's stopped drying the clothes aargh!!
Jul 12, 2009 | Hotpoint TDC32 Electric Dryer
Indesit condenser tumble dryer water light always on even though container empty
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Oct 06, 2008 | Dryers
Condenser tumble dryer water problem
Took advice...isolated from electricity supply...removed left side panel (side with condenser tank), to access the pump. Cleaned it all out (masses of water and grey lint!) and put it all back together again. Bit fiddly getting the panel back on...no screws left over...result!
All working great now.
Simpler solution maybe...There is a 'trap door' that can be removed, which gives access to the area where the water and lint accumulate.
1) Isolate from electricity supply.
2) Take out the condenser unit at the bottom LHS front of the machine (routine maintenance).
3) Underneath of where the condenser unit usually lives..at the back...reach in and open the 'trap door'. This needs a flat head screwdriver and you must release the two plastic clips holding the trap door.
4) You can now access the area where the water and lint accumulate...which makes the 'float' give a false container full fault.
5) Clean out this water and gunk regularly (once a month)!
Hoping this will avoid taking the side panel off again...
Jun 02, 2008 | Bosch WTE86300 Electric Dryer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Dryers Logo
104 people viewed this question
Top Dryers Experts
Marvin
Marvin
