The codes to program my remote for my emerson TV will not work. Are there additional codes other than what is in the user manual of my RCA converter box .. I tryed all 35 codes that are posted in the manual with no success.
Save yourself from this headache and pick up a $10 remote from Radio Shack or Walmart. Make sure it is a "Learning" remote. It will "learn" your system.
Posted on Jun 21, 2009
I want to program my universal remote to my Emerson TV (LC220EM2)
Hi all.
1. You must find the model number of your RCA universal remote.
2. You must search RCA.com for it or else google.com for "[model number of RCA remote] + operating manual"
Ignore all those who listed codes.. they have no idea what universal remote you have. All universal remotes have different code databases.
BTW... You most likely will not get any universal remote to work well with your TV. When you get done fiddling with universal, know that you can always purchase the OEM remote from link below (guaranteed to work without programming): SYLVANIA NH001UD Emerson LCD TV Remote Control
Oct 15, 2012 | Emerson LC220EM2 Remote Control
I have an rca universal remote without a code search button. i want to program it to a toshiba tv but can't. how do i program it?
You can try going to the RCA website and looking up the user manual for your model of universal remote. I happened to need to do that today for mine which also has no code search button. I found out that mine is a model RCR412BN. I was able to find the user instructions on how to set the codes for my TV, DVD and Digital converter by following these instructions on the RCA website ... worked great!
This is the model I have ..... http://www.rcaaccessories.com/universalremotes/?sku=RCR412BN
and here's the user manual online ... http://audiovox2.info/docs/rca_acc/man/RCR412BN_DOC_OM.PDF
Aug 16, 2010 | RCA Universal Remote Control
We have a RCA remote and need the codes for an Emerson TV. Can you help?
The codes to program an RCA RCU300WBL remote control for an Emerson TV are:
Code 004 for Emerson TV Code 006 for Emerson TV Code 012 for Emerson TV Code 023 for Emerson TV Code 025 for Emerson TV Code 026 for Emerson TV Code 029 for Emerson TV Code 030 for Emerson TV Code 033 for Emerson TV Code 035 for Emerson TV Code 036 for Emerson TV Code 037 for Emerson TV Code 038 for Emerson TV Code 041 for Emerson TV Code 042 for Emerson TV Code 043 for Emerson TV Code 046 for Emerson TV Code 047 for Emerson TV Code 048 for Emerson TV Code 049 for Emerson TV Code 073 for Emerson TV Code 123 for Emerson TV Code 162 for Emerson TV Code 171 for Emerson TV Code 177 for Emerson TV Code 179 for Emerson TV Code 191 for Emerson TV
If you have a different RCA, remote control you can post more details, or take a look at the RCA Code Finder Website at:
http://remotefinder.rca.com/default.aspx?site=rca
Aug 08, 2009 | RCA RCU300WBL Remote Control
RCA converter codes wont work on new emerson TV
Estos son algunos códigos válidos para TV Daewoo
11661
11909
10013
10092
10154
10217
10451
10556
10623
10661
10672
10865
Jan 12, 2009 | Televison & Video
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
Tv remote codes
I own a One-for-All universal remote, and my booklet says the setup code for an Emerson TV (without a built-in DVD or VCR) is one of the following numbers: 0154, 0171, 0178, 0180, 0236, 0451, 0463, 1944, 1963. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Emerson Televison & Video
I need codes for a rca d770
Programming For TV
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn’t, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
Emerson ..................1004, 1006, 1012, 1014, 1023
..................................1024, 1025, 1026, 1027, 1028
..................................1029, 1030, 1031, 1033, 1034
..................................1035, 1036, 1038, 1039, 1041
..................................1042, 1043, 1044, 1046, 1047
..................................1123, 1124, 1162, 1171, 1176
......................................................1177, 1179, 1191
Your user manual is available for download and option printing at the following link :
http://www.retrevo.com/s/RCA-D770-Universal-Remotes-review-manual/id/402ci568/t/1-2/
May 16, 2008 | RCA D770 Remote Control
Need code for Emerson TV,DVD,VCR Combo
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
303 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
