Question about Dual Electronics CECT P168 Cellular Phone
Usb not recognise
I have an i9 when i plugged in my usb all it does is charge my phone it does not show anymass storage or any of the sort that was mention all it shows is charger connected computer does not recognised it what can i do
  • 32 Answers
TRY PLUGGING IT INTO A DIFFERENT USB. IF THIS DOESNT WORK TRY CHECKING DEVICE MANAGER ON YOUR COMPUTER, THEN USB CONTROLLERS TO INSURE YOUR PORTS ARE FUNCTIONING CORRECTLY.
Posted on Jun 25, 2009
There is no instructionregarding on how to connect
When plugging into your pc connect the usb end 1st then the other end into your phone, it will say mass storage and web cam highlight mass storage and then ok it will charge from your pc. This bottom part I added to you other post I found 1st.
I am assuming its the same as the i9 with a usb cable which plugs into the computer to charge or a power socket for the wall charge. This should have been sent when you bought the phone, check the website you got the phone from and email asking where it is. Other wise you can buy the plug on ebay(Australia) for $2.53 free postage from store Hong Kong Outlets they have plugs for 5 different countries.
Hope this helps.
Dione
Mar 19, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Defective USB driver.
from where are you seeing the USB storage device? have you change slots where you put your usb?
If it still does not show any files, try to isolate if plugging to another computer, the files are there.
or, you can just right click the driver and format it if you no longer need those files inside the USB.
Aug 25, 2009 | Computers & Internet
My usb for cect i9 does charge phone
my cect i9 was not charging from usb I though it was the cable but after I took out battery and scrapped the 3 contacts on the batttery with my fingernail it started to charge and be recognized by computer again
Jul 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Webcam driver for i9
hello please i wana use my sci phone as my web cam but i cant found driver for that i need mt6225 please help me
May 31, 2009 | Dual Electronics CECT P168 Cellular Phone
My computer does not recognise my CECT i9 phone
Switch the phone on, then connect. You should have 3 options; Mass Storage, Webcam and PictBridge. Select Mass Storage. Depending on your system on your PC will connect immediately or maybe (older model) ask for driver. Driver for mass storage is 'generic' so will install automaticaly. After that go to 'my computer' and there will be 2 (!!!) new 'drives', the first one the external card on your phone, the second one the internal drive of your phone.
May 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Your computer "should" reconize this phone without any drivers. when you attach the usb cable it should come up on your phone a list of options mass storage, web cam etc. on your phone is where you would choose mass storage option. As for the Chinese see if this will help you.
This is a common issue which you should be able to correct by using one or more of the following methods;
1.) Change the E-Book reader option from the Main menu => Tools => E-Book reader => Options => Global settings => Encoding, change to "UCS2 (Unicode)"
2.) Globally set the phone to English by opening up the dialing pad and entering *#0044# and then press the call button.
here is an excellent sight for I9
i9forum.co.uk
Apr 11, 2009 | Dual Electronics CECT P168 Cellular Phone
Youneed to plug in the phone to the computer while the computer is off. Leave it plugged in, then turn on your computer. This will load the drivers from the phone needed for the computer to recognize it....
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
How to download to i9 phone
connect your phone to a laptop or pc using the usb cable...the phone will then show threee options....choose mass storage. this will then setup the phone so that you can see the memory avaiable on the phone under mycomputer. there will be two drives associated with the phone...the internal memory and the memory card. when you browse the drives you will see various folders...copy the media to the related folders.....hope this helps
Jan 07, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 wont charge battery is fine
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Dec 10, 2008 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
179 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
