Question about Kenmore 62602 Electric Dryer
The drum doesn't turn on my dryer, why? - Kenmore 62602 Electric Dryer
    Scholar:
  • 44 Answers
A couple of possibilities:
There is a belt that goes around the dryer drum. It may have broken or slipped out of place. If you remove the top of the dryer (usually pretty easy), you will probably see the belt going around the middle of the drum. (If not, maybe it broke.) It is loose? If so, it probably slipped off the motor or is broken (as you may find if you pull on it). If all this seems ok, you need to remove the front of the dryer. That's usually a little more complicated, but not too bad. Now you'll probably see the motor. On mine, it is on the lower right. Does the belt go around the motor pulley and the drum and is tight? If so, maybe the motor is broken.
At this point you need to know if the motor works, but that may not be really easy because opening the door usually breaks an interlock switch that stops the motor from turning. But if you are careful, especially with electricity, you may be able to bypass enough things to see if the motor turns. Alternatively, note the exact position that the motor pulley is in (mark it if necessary). Then reassemble the dryer, try to run the motor, and then open it again. Did the mark move?
At this point, you probably have enough information to see what needs to be fixed or replaced. One additional problem I had was that the motor pulley was slipping on its shaft. If a plastic/nylon part has broken, you may need to replace it. Of course, if the motor isn't turning, make sure that nothing is jamming it somehow (like a stray sock tightly caught in the belt). Hope this helps.
Posted on Jun 21, 2009
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: Drum doesn't turn..Motor sounds fine
replace the belt and idler pulley as a set sold at any Sears store
Posted on Aug 14, 2011
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 04, 2016 | Dryers
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
Dryer lights up but drum doesn't turn. Can manually move drum but difficult.
I would like by your description you have a obstruction in the blower wheel preventing the motor from turning freely. I would seek to find an item of clothes in the blower wheel preventing the motor from turning.
Thats where I would look, I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 08, 2011 | Amana NED7200TW Electric Dryer
When I try to turn on my dryer it just buzzes for about 5 seconds and doesn't do anything else. The heater doesn't turn on and the drum doesn't turn. Help!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 09, 2011 | Electrolux EIED55H Dryer
DRUM WONT TURN- The blower turns, the belt
heatman101
Jun 23, 2011 | Kenmore Dryers
I had my Daughters Bra in it and it caught somewhere and now the drum doesn't turn. I am thinking that since it ripped the bra to **** maybe a pce of it is caught in the drum runner. When I tried to...
When you turned it mannualy it probably popped the belt off the pulley.Also if it was a bra with a metal stay check to see that they are both still in the bra. Hope this helped.
May 17, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer not working I replaced the Thermal fuse and still not working.
Is the drum turning? If it's turning, then maybe the high-limit thermostat or element is bad. If drum doesn't turn, check lid switch.
Sep 26, 2010 | Kenmore 74672 Gas Dryer
Kenmore 62602 Electric Dryer Logo
133 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
