Question about Sport & Outdoor - Others
John Deere Gator won't start
Not sure what year model it is but it does have the Kawasaki FD620D-AS24 gas engine. It is new to me and I have not been able to get it started. I was told it was running and went to look at it and the starter solenoid was bad so I fixed that and it will turn over but won't start.
Both spark plugs are firing, the fuel pump is working,looking in the oil fill tube I can see the valves working up and down,it occasionall backfires through the muffler after choking.
After turning over for 10-15 sec with choke I can let it sit for 30-45 sec then it will try to hit immediately when I turn the key but then just whirls over like there is no gas in it. Also drained the carb and it semmed to have good clean fuel in it.
Don't really know what else to check. Any help would be appreciated.
Thanks Bill
  • 41 Answers
SOURCE: 1996 bayou runs for short time ,keeps stalling out
Hello, I would start first, make sure ex pipe is open . Then I would check the pick up coil, ohms should be 390-590 on a 300 KLF. Do this test before u start the bike Then start the bike and when it quits running check the pick up coil ohms. If good move on to the coil, If good then I would say good chance CDI is bad I hope this helps
Posted on Nov 26, 2008
SOURCE: 05 750 brute force missing badly
Just had same problem. Take carbs off and clean all jets and bowl. Be carful front and rear carb have different sized jets. When you put quad back together put entire airbox together even the cover. This quad will backfire unless air box is complete. I bet you anything your carb is full of trash.
Posted on Jan 22, 2009
  • 65 Answers
SOURCE: fb460v kawasaki will not start
check your camshaft to see if exhaust loab has been worn off. have seen this before
Posted on May 02, 2009
DoubleClutch
  • 376 Answers
SOURCE: 2000 Vulcan Nomad 1500 FI - Bike was sitting for 6
You need to remove the carbs and dismantle them completly and adjust them to spec. Also change the fuel filter.
Posted on Oct 28, 2009
miket756
  • 2702 Answers
SOURCE: coleman powermate maxa 5000 er
it could have sezed up on you take out the plug and try to turn the motor by hand if it wont turn its sezed up,,,if so all you can do is tip down the plug hole a small brop of red x or two stroke oil and rock the motor back and frow till it frees off,,
if it frees off that is!
Posted on Aug 30, 2010
John Deere Gator
check your gas tank screw on cap......if there is a breather hose coming out of the cap....make sure the hose is not kinked thus causing a vapor lock in the tank
Jul 07, 2014 | John Deere ATVs
2004 John Deere Gator CS
Hi, although i dont know what a gator cs is i would suggest you first check that your valves are opening to actually let your fuel mixture into the engine. If the valves are opening / closing at the correct time you need to check compression on all cylinders. you may have sticky rings or worse.
Sep 17, 2017 | Motorcycles
The voltage regulator/rectifier will not affect the starting. Pull a plug wire off, turn the key to try to start to check for spark. If it has no spark, replace the coil pack or make sure it hasn't rusted between the flywheel and the coil contact. You can get more detailed info for small engine spark and coils on you tube.
Dec 15, 2017 | Motorcycles
Sport & Outdoor - Others Logo
1,008 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
