Question about Toastmaster TLWTOB6 Lightwave Toaster Oven with Convection Cooking
Halogen light heater
The upper halogen light heater in my toaster oven has died.
How do I remove it and where do I get replacement?
  • vdutta Feb 12, 2009
    TLWTOB6 Lightwave Toaster Oven with Convection Cooking?
    Light bulb burned, don't know where to get the replacement.
I have same problem Took whole unit apart found upper bulb is connected with wire that goes through out. You hve to physically take bulb out through side without electronic panel wire is connected on panel sid with actual plug. but ended up cutting wire other side. Bulb is not like regular bulb you will have to hard wire one side of it. bulb is unseperable from wire. Still looking for replacement bulb. I sure miss my toaster I believe it will probably be chaper for me to buy new toaster vs replace bulb. The bulb is nothing like I have seen before.
Posted on Feb 27, 2008
Just as several others have written, our halogen light burned out, and the TWLTOB6 is pretty useless without it. It was PERFECT for reheating a slice of pizza, after 20 seconds in the microwave. If it is (as Jim7500 says) hard wired, then replacement is not a safe option.I believe this product was designed with "planned obsolescence" in mind. Our solution was to buy a new toaster oven without such a weak component (the light). Also, our TWLTOB6 got real hot once when toasting unattended. After that, setting the cook time was frustrating--the dial electronics were damaged.
Posted on Jun 11, 2009
Can I get parts for a Bravetti convection toaster oven, specifically upper elements?
Fixya does not sell replacement heating elements. Try checking with a local appliance parts supplier.
Aug 22, 2016 | Euro-Pro EP278 Bravetti Platinum 1500...
Can you get spare parts for a infra cheff
  • Infrachef Halogen Oven - Sears halogen oven Replacement Parts. Schedule Repair. ... Home / Results For: "infrachef halogen oven" 67 results found for ... Infra Chef Halogen Oven.
  • Campkin's Parts Store - InfraChef Family Sized Halogen Oven InfraChef Family Sized Halogen Oven . Web Price. $199.99. Category ... Quantity: Description: The revolutionary Infra Chef halogen oven is the all in one cooking ...
  • PROLECTRIX 7L HALOGEN OVEN SPARES REPAIR ' eBay > Search > PROLECTRIX 7L HALOGEN OVEN SPARES REPAIR Find best value and selection for your PROLECTRIX 7L HALOGEN OVEN SPARES REPAIR search on eBay. World's leading marketplace.
  • halogen oven spares > Search > halogen oven spares halogen oven spares. Try Prime All ... Mini Halogen Thermostat made for SPARES2GO to fit Cookshop Mini Oven ...
  • Chef Oven Spare Parts ' Appliance Spares Appliance Spares in Nobel Park offers oven spare parts by Chef across the Australia to the top most manufacturers. Buy Now chef spares parts!
  • Jun 02, 2016 | Toaster Ovens
    Halogen tabletop oven
    You can use any oven-safe dish that will fit inside the oven (preferably, with the low rack in place). I've seen 3 qt round casseroles that will fit when you aren't using the extender. (For example, this should fit: ) Some casseroles are sold with non-oven safe lids. Make sure that you check the temperature range for the specific dish. Some are only rated to 400 degrees F.
    Unfortunately, I do not know of any sources that sell the accessories separately.
    I hope this helps.
    Jun 03, 2013 | Fagor 12 Quart Halogen Tabletop Oven
    Need heating element (upper) for GE168947 toaster oven
    You should be able to install a new replacement element or a used element from another GE168947 toaster oven.
    Jul 03, 2012 | Toaster Ovens
    Need to check fuse or change out elements
    disconnect first the unit from power supply. pull out the fuse and check for the continuity of the terminals with an ohm meter, if there is no continuity,, replace the fuse. for heater, remove one heater terminal connection and check for the resistance reading.if no resistance read, replace the heater. ALWAYS DISCONNECT THE UNIT FROM POWER SOURCE BEFORE DOING THESE.
    Mar 27, 2011 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Sunbeam toaster oven upper heating coil not working
    the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
    Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
    Heating elements
    I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
    Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
    Light and oven does not turn on.
    :-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
    Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
    Toastmaster TLWTOB6 Lightwave Toaster Oven with Convection Cooking Logo
    811 people viewed this question
    Top Toastmaster Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dennis Boxerman
    Are you a Toastmaster Toaster Oven Expert? Answer questions, earn points and help others
