Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Not cooling my refrigerator is not cooling correctly
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Aug 03, 2009
Refrigerator part does not seem to working correctly .... not cooling well. Freezer (bottom) appears fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Kenmore Refrigerators
Freezer is at correct temperature, but fridge is warm. What can I try?
heatman101
Aug 16, 2011 | Frigidaire Refrigerators
Side by side main part not cooling freezer cools correctly model # ars2664bb0
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 08, 2011 | Amana Refrigerators
Freezer is cold; refrigerator is warm. dials are sets to correct levels. condenser seems to be working. lights go on.
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Dec 26, 2010 | GE Refrigerators
Freezer operating correctly. fridge not cooling, all lights are on etc. it started to cool got to 8 degrees then stoped cooling temp went up from there.
heatman101
Dec 25, 2010 | Samsung Refrigerators
Freezer has ice in the bottom from condensation, suspect that the defrost system is not working correctly. We periodically find water puddling under the freezer side.
heatman101
Nov 24, 2010 | GE Refrigerators
I have a 20.7 cubic feet Haier frost free refrigerator/freezer, model #HTQ21J*SS and the refrigerator part is not cooling. The freezer is working correctly at the same time.
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Haier HTQ 21 JABLSS 20.0 cu. ft. Full Size...
The top refridgerator is not cooling correctly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
fgmjfd
Sep 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Water is leaking inside the refrigerator and the ice cube aren't freezing completely (cube is a hollow shell of ice)
Possibly it is because fridge is not cooling correctly(Ice cubes hollow).. Suggest proper defrost. if it is cooling partially, it shows cooling is trying to take place (Make sure before you switch on after defrost, check for proper water drainage.Water must flow to the compressor once defrosted.Take note if the fan runs correctly.
Sep 20, 2009 | Whirlpool 18.9 cu. ft. Top Freezer...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
200 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
