Question about Goodman GMS90703BXA Heater
Gmp 0751-3 Everything seems fine until its time for the blower to kick in. The blower runs at slow speed and it seems like when its ready to kick into high speed nothing.The flame goes out.
  • 59 Answers
There is a sensor that senses if the heater has an adequate VENT like an oxygen sensor on a car, if that has gone bad the heater will think the blower is not blowing and shut everything down to avoid building up gases in the home.Also check the tube that vents to the outside.If it is clogged the same problem will occur.I am no expert but when my heater went out last year I was forced to learn the ins and outs of heaters.HOPE THIS HELPS.
Posted on Nov 03, 2007
Blower mtor on 1997 Chevy 1/2 ton 4wd runs real slow or not at all,some times it speeds up to near normal speed.
Yes, the blower motor is bad, replace it. This is exactly what you say, brushes are worn.
Dec 04, 2013 | Cars & Trucks
AC fan blows less air after extended use
Sounds to me the blower motor is on it's way out and should be replaced. Even though they sound like there working doesn't mean everything is ok with it there are different parts on it that could go wrong and they way to fix it is with another blower fan and not a bad idea to do the resistor at the same time located in the blower box with about 4 wires coming out of it with one or two screws holding it in place all is located under dash behind the glove box area.
Aug 03, 2012 | 2002 Dodge Grand Caravan
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
The outside unit runs but the inside doesn't blow
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
2005 jeep grand cherokee 4.7 Ac fan lost the 3 lower settings, only the high setting still worked. For a while the lower fan settings would just come on, and then go out again. The high fan setting...
Well, the blower resistor handles the lower speeds and the hi-blower relay handles the hi speed only. if the fan still works on the lower speeds then the resistor is bad. if the fan doesn't work at all then your motor has failed and or burn't the relay out also. if you can get your blower to start by hitting the kick panel above the pass. side foot area then the motor is bad. if you are handy enough to drop the kick panel and access the motor then check the connections at the motor. Then wack the motor and see if it comes on then. you will most likely find the problem if you follow those simple rules above. Good luck.
Jul 31, 2008 | 2001 Jeep Grand Cherokee
Goodman GMS90703BXA Heater Logo
94 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
